Renting a spray booth or???
#3065375
08/05/22 12:13 AM
08/05/22 12:13 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Buying a portable spray booth
I’m considering doing my own paint work and I’m going to obviously need a booth to ur
I’m told u can rent a spray booth at a local shop. But what kind of cost is that
I can buy a inflatable and portable spray booth for about 700 shipped. Has anyone ever Used on and how did it work
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Renting a spray booth or???
[Re: gremlinsteve]
#3065385
08/05/22 06:17 AM
08/05/22 06:17 AM
Posts: 20,034 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Rent a booth at a local shop? Maybe if you are good friends with the owner, I suppose, but no reputable shop is going to let some random dude off the street use their booth.
I've never used a portable spray booth, but if you are really looking to save money, you can make one in your garage. Plastic drop cloths, some box fans, wet the floor down before you shoot.
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#3065397
08/05/22 08:49 AM
08/05/22 08:49 AM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
Years ago I painted a VW outside. I made a 2 x 4 frame and draped it with plastic. Worked out great as the lighting was excellent. One of my best paint jobs ever.
I have also successfully put plastic up in a garage and used a blower to suck air through pleated filters taped to the plastic. Worked ok but it was hard to keep the blower from sucking the plastic in.
[Re: topside]
#3065411
08/05/22 09:33 AM
08/05/22 09:33 AM
not_a_charger
I can't rent or borrow a booth even from places I worked at; they're just too busy and/or don't want to be there after-hours to watch over it. That too, and most of the time a booth is used off-hours, it's either the owner doing his own stuff, or side jobs, or letting his techs do side jobs.
DBAP
[Re: not_a_charger]
#3065428
08/05/22 10:13 AM
08/05/22 10:13 AM
Posts: 1,096 Waddell AZ
azblackhemi
Waddell AZ
There are e few places here in Phoenix that rent spray booths. Been that way for years. Here's an example. https://www.facebook.com/marketplace/item/717719809287990/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A16f6d93f-6084-4e65-9e13-6c794a6af858 Sorry I thought it would be a clickable link.
[Re: not_a_charger]
#3065443
08/05/22 11:10 AM
08/05/22 11:10 AM
gremlinsteve
houston texas
Yea that’s actually what I was thinking. Who’s going to allow some nobody into there paint booth
Hence me looking for a solution. I would paint in my shop but I have a lot of stuff I don’t wanna paint. So moving it out would literally take hours
But it is an option
[Re: cudaman1969]
#3065528
08/05/22 04:47 PM
08/05/22 04:47 PM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
Hmmm. I like the idea of being outside under plastic, after painting is done seal it up and let the sun bake it in there (greenhouse affect) I imagine on a hot day it could get up to 150 or more in there. Just like factory. I made a temporary paint booth out of PVC tubing and the thickest mil plastic sheeting and an old furnace "squirl cage" blower to paint the hood on my wife's Town and Country and a few motorcycle parts. The inlet fresh air was filtered with furnace filters along with filtered exhaust air was filtered. Used it for a couple of days and then took it apart. Neighbors at first thought it was a "green house" for something else until they saw what I was doing and also figured out that if I was doing what they first thought I would not have put it in the driveway of the workshop garage. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Didn't cost me that much to make and worked fine for what I needed to do. Mike
[Re: A12]
#3065548
08/05/22 06:01 PM
08/05/22 06:01 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Try not to laugh too hard, it actually worked and I even had LED lighting and worked into the night. You can make it any size you like and if you have enough room in your garage or out building (barn/pole) you can leave it up for a while. Yep a fine piece of "hillbilly engineering", kind of sad and disappointed that I took it apart too soon ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Mike Hillbilly maybe, but I like it. Great job.
[Re: A12]
#3065551
08/05/22 06:06 PM
08/05/22 06:06 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Try not to laugh too hard, it actually worked and I even had LED lighting and worked into the night. You can make it any size you like and if you have enough room in your garage or out building (barn/pole) you can leave it up for a while. Yep a fine piece of "hillbilly engineering", kind of sad and disappointed that I took it apart too soon ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Mike What are the pipes made of, looks like pvc? I have 4 cars to paint in the coming months
[Re: cudaman1969]
#3065557
08/05/22 06:31 PM
08/05/22 06:31 PM
A12
N.E. OHIO, USA
Try not to laugh too hard, it actually worked and I even had LED lighting and worked into the night. You can make it any size you like and if you have enough room in your garage or out building (barn/pole) you can leave it up for a while. Yep a fine piece of "hillbilly engineering", kind of sad and disappointed that I took it apart too soon ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Mike What are the pipes made of, looks like pvc? I have 4 cars to paint in the coming months Yes PVC. I did "bolt" some sections together for extra strength and decreased the radius of some of the ends so I could take sections apart if needed. But if you want it strong then just glue them together like you would if it was plumbing and if you need to take it down a sawsall will do the trick quickly. Also made some of the sections the size of the furnace filters I was going to use for the inlet air and for the sized one area for the blower so I could seal it more easily.
[Re: A12]
#3065694
08/06/22 07:56 AM
08/06/22 07:56 AM
cudaman1969
fredericksburg,va
Try not to laugh too hard, it actually worked and I even had LED lighting and worked into the night. You can make it any size you like and if you have enough room in your garage or out building (barn/pole) you can leave it up for a while. Yep a fine piece of "hillbilly engineering", kind of sad and disappointed that I took it apart too soon ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Mike What are the pipes made of, looks like pvc? I have 4 cars to paint in the coming months Yes PVC. I did "bolt" some sections together for extra strength and decreased the radius of some of the ends so I could take sections apart if needed. But if you want it strong then just glue them together like you would if it was plumbing and if you need to take it down a sawsall will do the trick quickly. Also made some of the sections the size of the furnace filters I was going to use for the inlet air and for the sized one area for the blower so I could seal it more easily. Uhh, how do you get the car into that thing?
[Re: cudaman1969]
#3065725
08/06/22 11:15 AM
08/06/22 11:15 AM
A12
N.E. OHIO, USA
I could have made it large enough to get the car or even a truck/van into it but I only needed to paint a hood and a few removable parts from my wife's T&C. Also I did a bunch of motorcycle parts, i.e., frames, gas tanks, side panels, fenders, headlight, swingarm, etc., so it worked out perfect for what I needed. You can make it just about any size you need or want. You can see how I did the "roof" and I bolted some of those cross members in case it rained and I was lucky I did that as it did rain "pour" heavily a few days after I finished. If you make this inside a large garage or building some of the extra strength bolting shouldn't be necessary. Like I said I only made it large enough for the projects I had and I wanted it to be temporary and as less expensive as possible. Talk about cheap I thought about making two swinging "doors" on one end with zip ties for hinges ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Sit down and figure out what size you need and head off to Lowe's or Home Depot and buy the connections in money saving bulk packs and don't forget the duct tape Mike
[Re: A12]
#3065764
08/06/22 01:10 PM
08/06/22 01:10 PM
cudaman1969
fredericksburg,va
I could have made it large enough to get the car or even a truck/van into it but I only needed to paint a hood and a few removable parts from my wife's T&C. Also I did a bunch of motorcycle parts, i.e., frames, gas tanks, side panels, fenders, headlight, swingarm, etc., so it worked out perfect for what I needed. You can make it just about any size you need or want. You can see how I did the "roof" and I bolted some of those cross members in case it rained and I was lucky I did that as it did rain "pour" heavily a few days after I finished. If you make this inside a large garage or building some of the extra strength bolting shouldn't be necessary. Like I said I only made it large enough for the projects I had and I wanted it to be temporary and as less expensive as possible. Talk about cheap I thought about making two swinging "doors" on one end with zip ties for hinges ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Sit down and figure out what size you need and head off to Lowe's or Home Depot and buy the connections in money saving bulk packs and don't forget the duct tape Mike Thanks will do, I have some conduit left over and was looking at them this morning going hmmm
