Which 4 BBL manifold & carb 4 project-UPDATED?
#306528
05/03/09 03:42 PM
05/03/09 03:42 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Guys, I need help fast. Well, not fast, but I wanted to paint one of these today. I am doing this 67 Power wagon, short wide with a 4 speed and real low granny gear. Its going to be a driver for around town when done. Its a little 318 LA. It runs well, but I am redoing the truck and changing the valve covers and want to ad a 4 BBL manifold and carb.
So, I have these two manifolds and need to buy a carb. I dont want to spend a ton, as this is a low buck project. But, its going into a cold climate and I want it to start and want it relaiable.
so that in mind, which one of these manifolds will work best and what carb should I buy. I dont mind buying new as I want it issue free.
thanks
Re: Which 4 BBL manifold & carb 4 project-pics attached?
[Re: 1_WILD_RT]
#306533
05/03/09 04:02 PM
05/03/09 04:02 PM
RUMBLON
Cambridge Idaho
The bottom manifold is non-EGR which is a plus... But if you plug the EGR they are about the same & the non-EGR manifold is probably a 71 3400 intake so someone might really like to have it for a FAST project....
Randy, first and this will sound dumb, but whats the EGR, and you mean the orange one is non EGR? I dont mind plugging the EGR and using the other and then using the orange one for some other project.
is it an exhaust gas some or rather?
and what carb with the EGR manifold should I use.
[Re: 1_WILD_RT]
#306535
05/03/09 04:54 PM
05/03/09 04:54 PM
RUMBLON
Cambridge Idaho
The orange one is non-EGR, EGR = Exhaust Gas Recirculation, viewed from the front to the right of the carb flange is two passages & two bolt holes, one passage is exhaust from the crossover passage, the other feeds both planes of the intake through holes below the carb...
Those manifolds are speadbore design & accept a Carter Thermoquad or a Rochester Quadrajet... Both carbs were used by Chrysler but the Thermoquad is much more common & when setup correctly is a great carb...
OK, so a thermoquad then? Can I buy it new, or do I need to find one that is rebuilt. And I assum that an aftermarket like edelbrock wont work and if so, what CFM? electric choke or on electric?
thanks again
[Re: DaytonaTurbo]
#306538
05/04/09 08:56 AM
05/04/09 08:56 AM
RUMBLON
Cambridge Idaho
Also you could buy the carb that I have sitting around doing nothing, a holley 650cfm double pumper spreadbore. Would bolt onto that manifold perfectly...
that sounds like a lot of carb for this application?????? what shape is it in and how much?
[Re: RUMBLON]
#306539
05/04/09 09:10 AM
05/04/09 09:10 AM
RapidRobert
The top one has the thermostat housing clocking different for an A/C application. I'd consider a 1&3/8" primaries thermoquad from Demonsizzler.
[Re: 5thAve]
#306541
05/05/09 03:27 AM
05/05/09 03:27 AM
Posts: 5,449 Woodbridge,CA
NAS Backyard
Woodbridge,CA
Dave, I would stay with the 2 barrel and points in IMO. For what your using it for you would be wasting your money . People forget that 2 barrel carbs were the bread and butter of engines for years. The only car I have that starts on the first hit is the one with the 2 bl. and points. I guess I'm old fashion and try to keep things simple. Plus your dealing with the best engine Chrysler ever built, why mess with it?
1970 Challenger Ragtop 426 4 speed
1961 Olds 88 2 dr Sedan 394 4 speed GVOD
1968 Pontiac Firebird 428 4 speed
2000 Ford F-150
2002 HD Roadking
1961 Licence Plate collection
1995 Buick Roadmaster
www.nogreenautolaws.com
[Re: NAS Backyard]
#306542
05/05/09 04:29 PM
05/05/09 04:29 PM
RUMBLON
Cambridge Idaho
Tim, maybe your right. My main reason for swaping out the manifold and carb, is that the carb leaks and I tried fixing it and it didnt work. So I figured if I was replacing the carb, then I may as well us a manifold I have sitting here.
Let me ask another question, why not an electronic ignition with a 2 BBL? Or is there any reason to use alectronic ignitin in the first place. I have the manifold about off and it needs to be cleaned and sand blasted and re painted if nothing else.
any other suggestins?
[Re: RUMBLON]
#306543
05/05/09 05:00 PM
05/05/09 05:00 PM
Posts: 5,181 CT
GTX MATT
CT
Everyone complains about points but I personally love them. Ive never had starting problems on my points engines. Electronic ignition could be considered more reliable, but I dont think so people always have trouble with the boxes.
I think his point was just that you wont really get any extra power out of the electronic unit if your points are already working correctly, if you get anything its probably not worth it since you're not worried about power and the difference wont be noticeable (although you may find a difference would be due to a better timing curve, which would be noticeable but you could recurve your current dizzy).
[Re: GTX MATT]
#306544
05/05/09 05:17 PM
05/05/09 05:17 PM
RUMBLON
Cambridge Idaho
I have the valve covers off. the ones in these more recent pics are not the ones that came on the engine. I have them off to be painted. Here is a shot of the cvalve train and with the 2BBL manifold off of the truck. It looks like some of the areas on the 2BBL are clogged? what ya all think???? The other reason I was taking this 2BBL off, is because there are a LOT of unused areas. vacumn, ect that are all blocked off in one backwards way or another, see pics. They just piched the end of the (what ever its called there the EGR maybe) and then covered that exit with several plugs and it looks like CR@P.I am honestly a horible mechanic. I HATE IT! due mostly in part to the fact that my hands do not work. this took me literally hours and my hands are unusable the rest of the day. Thats why I love the body and paint, larger tools and no real issues. Just metal fab, welding, plasma and a little for the areas I was not talented enough to get straight. But I hate unsightly engine bays, so this is the only other reason I tore this down. suggestions from the pros. Dave Dave
