Re: 632 BBC on the dyno
[Re: AndyF]
#3065153
08/04/22 12:30 PM
08/04/22 12:30 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Could berelief valve or poor oil return something some of the big chief style stuff is known for. Also having the vacuum pump hooked up is not going to help that. Not unusual for us to have to add extra oil on the dyno. Be curious to see what he finds, the SB in the Vette we have to run a couple extra quarts in it, just does not seem to like running on the dyno in a static position, in the car we go back to 6qts with no issues, I know crazy.
[Re: Al_Alguire]
#3065164
08/04/22 12:53 PM
08/04/22 12:53 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Very nice! I'm building a 475" BB Chevy right now for my "shop truck".
[Re: an8sec70cuda]
#3065205
08/04/22 02:57 PM
08/04/22 02:57 PM
Posts: 4,694 Wichita
GY3
Wichita
Is the distributor shaft seated correctly?
Some of them have a slip collar and the shaft moves up or down too far and won't let oil pass correctly there.
[Re: Al_Alguire]
#3065239
08/04/22 04:00 PM
08/04/22 04:00 PM
Posts: 31,052 Oregon
AndyF
Could berelief valve or poor oil return something some of the big chief style stuff is known for. Also having the vacuum pump hooked up is not going to help that. Not unusual for us to have to add extra oil on the dyno. Be curious to see what he finds, the SB in the Vette we have to run a couple extra quarts in it, just does not seem to like running on the dyno in a static position, in the car we go back to 6qts with no issues, I know crazy. We took the belt off the vacuum pump and that helped with the oil pressure. We were able to make a full pull on the dyno but when we finished the pull the oil pressure dropped way down at idle so we shut it off. This is the second time on the dyno. The first time the valve covers filled with oil and we couldn't make a pull. He added drain back hoses and had a new pan built. Those changes fixed some issues but it still isn't quite right. We had 8 qts in a 7 qt pan which might have been too much. We didn't want to run it low since we knew the valve covers would hold oil. I suppose we could've tried higher and lower oil levels to see if there was a solution.
[Re: AndyF]
#3065405
08/05/22 09:16 AM
08/05/22 09:16 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
What oil pump/bypass spring, and oil restrictors?
I've struggled with a few BBC with billet pumps that just moved too much oil upstairs for the pan volume.
This is the last 632 I ran on dyno
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#3066173
08/08/22 09:52 AM
08/08/22 09:52 AM
an8sec70cuda
We had that issue w/ a Dart block small block a several years ago. We tried a billet Melling oil pump and it pumped way too much oil up top...starved the bearings. Went back to a regular HV pump and no more issues.
