Power window ?? #3064731
08/02/22 07:45 PM
08/02/22 07:45 PM
mn
flyman Offline OP
flyman  Offline OP
mn
I was trying to replace the power window motor on my 90 power ram. I lost the tension on the regularor. Does anybody know how much tension or preload goes in the regulator before locking down with the motor??
Re: Power window ?? [Re: flyman] #3064742
08/02/22 08:21 PM
08/02/22 08:21 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
is the spring still on the regulator or in the bottom of the door? i changed from man to power and dropped my reg and spring flew off. it was a cluster to get it wound back up after about 6 times i felt good about it and left it alone.
Re: Power window ?? [Re: trw1982] #3065009
08/03/22 07:28 PM
08/03/22 07:28 PM
mn
flyman Offline OP
flyman  Offline OP
mn
The problem is the reg is out of the door. and the motor is orr the reg. Im not sure if one turn is enough or do I need more?
