Gas tank options #3064197
07/31/22 11:22 PM
07/31/22 11:22 PM
houston texas
gremlinsteve Offline OP
houston texas
Anyone used a mustang tank on a 73-81 style d100?
I’m fighting some old varnish I can’t seem to get cleaned out of
My stock saddle tank
So I’m just about ready to just install a new mustang tank behind the rear axle
I know they can fit the older 64-72 models.
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Gas tank options [Re: gremlinsteve] #3064458
08/01/22 07:07 PM
08/01/22 07:07 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Never did it but do know the mustang sender should work with your original gauge. Same ohm scale.
Mustang tank is rear fill, might be a problem loading the bed with a filler neck in the middle.
Angry white pureblood male
Re: Gas tank options [Re: gremlinsteve] #3064496
08/01/22 09:07 PM
08/01/22 09:07 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
A radiator shop (yes, just about all of them are gone now) can't boil the original tank out? shruggy
Re: Gas tank options [Re: Hugh Jorgan] #3064508
08/01/22 09:53 PM
08/01/22 09:53 PM
houston texas
houston texas
I’m using simple green and purple stuff. Concentrated and not diluted. Trying to clean it out
The tank is plastic. And here is the brand new gas I had just added to it
It’s bad
Re: Gas tank options [Re: gremlinsteve] #3064510
08/01/22 10:02 PM
08/01/22 10:02 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Dang need to do my Lil Red, was figuring simple gree and hot water. I know in metal tank MEK cleans them !! Not sure what it would do for a plastic. Have an extra gas tank , split on corner, wonder how i can patch?
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Gas tank options [Re: hulmule] #3064512
08/01/22 10:07 PM
08/01/22 10:07 PM
houston texas
houston texas
I have a local shop that can do steel tanks. But since this one is plastic I’m stuck fix in it myself
Plus there rather exspensive these days. My gremlin tank is steel so I had the clean it out. Then they coated the inside and outside with a rubber like coating to preserve the tank
Cost 400 bucks
Re: Gas tank options [Re: gremlinsteve] #3064610
08/02/22 11:28 AM
08/02/22 11:28 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Hopefully member Scratchinfotraction will chime in. I'm about 90% sure he put a Mustang tank in his.
Re: Gas tank options [Re: Fat_Mike] #3064612
08/02/22 11:36 AM
08/02/22 11:36 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried the local quarter car wash to pressure wash the tank out?
Re: Gas tank options [Re: stumpy] #3064616
08/02/22 12:13 PM
08/02/22 12:13 PM
houston texas
houston texas
Good idea
Re: Gas tank options [Re: gremlinsteve] #3064653
08/02/22 01:40 PM
08/02/22 01:40 PM
moparx Offline
moparx  Offline
the car wash works pretty good, but you almost need a buddy to help hold the tank in one place while you blast the insides clean.
the other patrons will get a good show as you chase the tank around the bay with the sprayer. biggrin
beer
Re: Gas tank options [Re: moparx] #3064717
08/02/22 06:28 PM
08/02/22 06:28 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Go down to Ace hardware or Home Depo and get the drain cleaner in the black plastic jug, pure lye, comes in its own plastic bag around it. Same thing in those other cleaners (Super Clean) but in lower concentrations. WEAR long gloves designed for this stuff, also glasses. Follow directions on jug. A friend worked in the meat department at A&P and when floor got to gummy from the cuttings he would get Draino and mop the floors. That stuff would eat up street shoes so he used his fishing boots, when done floor was spotless. Don’t get the ‘safe’ stuff, useless, has to say LYE. Also eats rust, paint, scum when put in vat. That's all furniture strippers use, WEAR protective gear!!
Re: Gas tank options [Re: ruderunner] #3064784
08/02/22 09:45 PM
08/02/22 09:45 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Maybe a flip down tag bracket like some later 70's cars had?
Re: Gas tank options [Re: mgoblue9798] #3064828
08/03/22 08:36 AM
08/03/22 08:36 AM
N
NITROUSN Offline
NITROUSN  Offline
N
For cripes sake its just a dirty tank. Clean it and move on.
Re: Gas tank options [Re: NITROUSN] #3065023
08/03/22 08:46 PM
08/03/22 08:46 PM
houston texas
houston texas
Simple green did the trick
Re: Gas tank options [Re: gremlinsteve] #3065051
08/04/22 12:28 AM
08/04/22 12:28 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Ramcharger tank is an option.
Kevin.
Re: Gas tank options [Re: Twostick] #3065178
08/04/22 02:19 PM
08/04/22 02:19 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I would do the RC tank now IF you can find one. If not, I agree Simple Green or White Vinegar and pressure wash. I've never tried the Lye etc.
Also, when you re-install, I would add some cushioning where the straps grab the tank the most. These were prone to cracking. That's how I lost mine but fortunately it's a dual tank truck so I'm just running off the in cab tank. Plus, I ran dual exhaust so removing the frame mounted one allowed me room to run the exhaust for the left side, which is a benefit of the RC tank too.
Facts are stubborn things.
Re: Gas tank options [Re: larrymopar360] #3065206
08/04/22 02:58 PM
08/04/22 02:58 PM
houston texas
houston texas
Do they repop the ram charger tank
Re: Gas tank options [Re: gremlinsteve] #3065256
08/04/22 04:40 PM
08/04/22 04:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
While the Ramcharger tank is possible it is not that easily done. There is a lot more needed that does not meet the eye. If you had a doner tank still in the Ramcharger you could get everything and you would also see what I mean. Plus you will have to figure out on how to fill it. I would fix what you got and run it.
Re: Gas tank options [Re: NITROUSN] #3065263
08/04/22 05:07 PM
08/04/22 05:07 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
It's not hard at all. Trickiest part is swapping out crossmembers. Tank fits in the area the spare would normally occupy. The Ramcharger fill neck points to the side, so you could 'move' the fill door back on the bedside, or just bring it up into the bed behind the wheel tub. The rest is just a matter of extending wire and hose.
I had a '76 Club Cab I swapped a 35 gal RC tank into. Used just basic hand tools. I did the swap because the original saddle tank had split near the fill. It put weight were it was needed and made running dual exhaust a snap. I ran the fill neck into the bed.
I still have the tank and straps if you're interested. You would just have to source the crossmembers.
The only possible issue I see with an RC tank in your truck is that your truck is lowered. The RC tank (especially the 35 gal one) does hang down some. You could get a rough idea how far down by holding a strap in place.
John
Re: Gas tank options [Re: SattyNoCar] #3065456
08/05/22 12:21 PM
08/05/22 12:21 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
What about a '68-'70 B-body (except Charger) tank ?
The filler neck is pretty low, being at license plate height.
The filler neck location could also be tweaked to get the cap access higher if needed.
It would require some cleverness to mount the fore/aft tank straps, though.
