'06 Magnum Questions - TPM & Headlights #3064423
08/01/22 04:55 PM
08/01/22 04:55 PM
Sin City
calif67rt Offline OP
Sin City
I have an '06 Magnum with a little over 100k miles.
1. The "Check TPM System" just started popping up in the warning window. It was registering 28 - 30 psi in the tires. I put in air to 35 psi and started the car. Same check system notice came up and showed 34 psi in all of the tires. Is this something a tire shop or mechanic can take care of or do I need to take it to a dealer?
2. Several years ago I bought aftermarket headlights as the factory lights had glazed over to the point it didn't do any good to polish them. But the adjustment screws don't work. At night it is like I am looking for squirrels in the trees on side of the road. Any suggestions on good aftermarket headlights that I can buy and install that will work properly?
Thanks for you help.
Re: '06 Magnum Questions - TPM & Headlights [Re: calif67rt] #3064554
08/02/22 06:41 AM
08/02/22 06:41 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Not much help for the headlights, but the tire pressure system may need to be reset. I think you just drive it for so many miles and it fixes itself.
Re: '06 Magnum Questions - TPM & Headlights [Re: MI_Custumz] #3064555
08/02/22 06:44 AM
08/02/22 06:44 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Do you still have the original headlamps
Re: '06 Magnum Questions - TPM & Headlights [Re: moparjim79] #3064560
08/02/22 07:01 AM
08/02/22 07:01 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
If he does he can do this:
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: '06 Magnum Questions - TPM & Headlights [Re: 3hundred] #3064600
08/02/22 10:55 AM
08/02/22 10:55 AM
Sin City
Sin City
Sorry but I don't have the old headlights. The body shop that replaced them while doing other body work threw them out.
The video looks like a good solution. I will remember it if I ever have to clean the headlights again.
Re: '06 Magnum Questions - TPM & Headlights [Re: calif67rt] #3064611
08/02/22 11:32 AM
08/02/22 11:32 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked EBay for good used OEM headlight assemblies?
Re: '06 Magnum Questions - TPM & Headlights [Re: stumpy] #3064615
08/02/22 12:12 PM
08/02/22 12:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Some aftermarket headlamp assys have crappy adjustment mechanisms.
You have to check them right away and return/exchange if they don't work.
The cheaper the part, the more likely the problem.
About every 2 years or so I polish the plastic lenses on the ol' Breeze: rubbing compound and a small wool cutting pad work fine.
If the lenses are really bad, wet-sanding with 1000-1500 and then polishing has worked on several different cars.
But if the plating on the reflectors has deteriorated, they're junk.
Re: '06 Magnum Questions - TPM & Headlights [Re: topside] #3064648
08/02/22 01:25 PM
08/02/22 01:25 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The TPMS has sensors at each wheel and the sensors have a battery in them. The batteries die over time and the sensor(s) need replacing. Any tire shop can do this.
Re: '06 Magnum Questions - TPM & Headlights [Re: calif67rt] #3065278
08/04/22 06:33 PM
08/04/22 06:33 PM
Mentor, OH
doggs330 Offline
doggs330  Offline
Mentor, OH
Autozone use to have a loaner diagnostic tool that would communicate with the TPMS. They changed out a bunch of the loaner tools a year or two ago so I'm not sure if it's still available.
Re: '06 Magnum Questions - TPM & Headlights [Re: John_Kunkel] #3065290
08/04/22 07:12 PM
08/04/22 07:12 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
This. I waited until I needed new tires though because as part of the valve stem, the tire has to come of the rim and therefore needs rebalancing. DO NOT let any tire shop tell you they need to program the new TPMS to your car! Scam. Just buy the Mopar ones so you'll get decent quality and they program themselves once you drive about a mile or less. I JUST replaced them on my 2010 Charger and the light went off in less than a mile. They have a 6-10 year battery life expectancy.
Facts are stubborn things.
Re: '06 Magnum Questions - TPM & Headlights [Re: larrymopar360] #3065504
08/05/22 03:12 PM
08/05/22 03:12 PM
Rio Linda, CA
Rio Linda, CA
No need to remove the tire to replace the sensor, breaking the bead on the sensor side is all that's needed. Don't confuse "relearning" with "programming", every new sensor needs to relearn and driving a while should do that.
Re: '06 Magnum Questions - TPM & Headlights [Re: John_Kunkel] #3065538
08/05/22 05:15 PM
08/05/22 05:15 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I don't know what a scamming tire shop might call it; "We need to use our programmer to set up your new sensors" for example. Whatever they call it don't go for it. As I wrote before, just driving does the trick. And I guess you can fit the new TPMS past the tire by breaking the bead, but I'd still wait until I was replacing tires. I don't think it's worth the expense. Just my opinion.
Re: '06 Magnum Questions - TPM & Headlights [Re: larrymopar360] #3066063
08/07/22 03:10 PM
08/07/22 03:10 PM
Sin City
Sin City
I have driven the car around for a while. The screen still shows check system then shows the air pressure in each tire correctly. So I don't think it is the sensor in the tires. I called the tire shop and they said it would cost about $300 to replace all 4 sensors. They said their own brand does not work well with Mopars so they said to replace them with OEM sensors. But when I told him the the system was reading the tire pressure correctly, he seemed puzzled. So I am taking it in in the morning and they will do a free diagnostic to see if it is something else.
I will let you know the outcome when I get it.
Thanks for the help.
Re: '06 Magnum Questions - TPM & Headlights [Re: calif67rt] #3066078
08/07/22 04:10 PM
08/07/22 04:10 PM
Rio Linda, CA
Rio Linda, CA
An alternative is the appcar app, with it you can turn off the TPMS. If you do regular maintenance the TPMS can be a costly nuisance.
https://appcar-diagfca.com/en/
Re: '06 Magnum Questions - TPM & Headlights [Re: John_Kunkel] #3066235
08/08/22 01:58 PM
08/08/22 01:58 PM
Sin City
Sin City
Went to the tire shop this morning. They said that all 4 sensors are reading correctly but the 2 on the left side are a little slow. They did as much as they could do and recommended I take it to the dealer. Not. Looks like I will be buying the appcar diagnostic software and turning the system off.
Thanks for all of the help.
Bill
Re: '06 Magnum Questions - TPM & Headlights [Re: John_Kunkel] #3066260
08/08/22 02:58 PM
08/08/22 02:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Awesome idea but $50...
For my Nissan Rogue, I just put a small patch of black electrical tape over the light..
Just my $0.02... wink
Re: '06 Magnum Questions - TPM & Headlights [Re: Sinitro] #3066301
08/08/22 05:41 PM
08/08/22 05:41 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I don't see where you say you actually checked the air pressure, only where you say the system shows it's okay. I guess the tire shop must've checked the pressure though.
Until I was ready for new tires and had my TPMS replaced in each wheel, I also went with the small piece of electrical tape up
Re: '06 Magnum Questions - TPM & Headlights [Re: larrymopar360] #3066311
08/08/22 06:24 PM
08/08/22 06:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Electrical tape - isn't that how ya fix a Check Engine light ? laugh2
Oh heck yeah, I have stories...
Re: '06 Magnum Questions - TPM & Headlights [Re: topside] #3066504
08/09/22 11:34 AM
08/09/22 11:34 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Definitely NOT a CEL! laugh My only CEL on my 5.7 was Coolant Temp Sensor and I addressed that immediately. The electrical tape was a savior until it was time for new tires, but admittedly it felt really good to remove it and clean the cover and have no lights up
Re: '06 Magnum Questions - TPM & Headlights [Re: larrymopar360] #3067042
08/11/22 11:39 AM
08/11/22 11:39 AM
moparx Offline
moparx  Offline
the "check engine" light means you need to look under the hood to see if the engine is still there, that no one stole it.......... biggrin
beer
