Gas tank options
#3064197
07/31/22 11:22 PM
07/31/22 11:22 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
Anyone used a mustang tank on a 73-81 style d100? I’m fighting some old varnish I can’t seem to get cleaned out of My stock saddle tank
So I’m just about ready to just install a new mustang tank behind the rear axle
I know they can fit the older 64-72 models.
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Gas tank options
[Re: gremlinsteve]
#3064458
08/01/22 07:07 PM
08/01/22 07:07 PM
Posts: 5,846 ohio
ruderunner
ohio
Never did it but do know the mustang sender should work with your original gauge. Same ohm scale.
Mustang tank is rear fill, might be a problem loading the bed with a filler neck in the middle.
Angry white pureblood male
[Re: Hugh Jorgan]
#3064508
08/01/22 09:53 PM
08/01/22 09:53 PM
gremlinsteve
houston texas
I’m using simple green and purple stuff. Concentrated and not diluted. Trying to clean it out
The tank is plastic. And here is the brand new gas I had just added to it
It’s bad
[Re: gremlinsteve]
#3064510
08/01/22 10:02 PM
08/01/22 10:02 PM
Posts: 1,411 northeast ohio
hulmule
northeast ohio
Dang need to do my Lil Red, was figuring simple gree and hot water. I know in metal tank MEK cleans them !! Not sure what it would do for a plastic. Have an extra gas tank , split on corner, wonder how i can patch?
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#3064512
08/01/22 10:07 PM
08/01/22 10:07 PM
gremlinsteve
houston texas
I have a local shop that can do steel tanks. But since this one is plastic I’m stuck fix in it myself
Plus there rather exspensive these days. My gremlin tank is steel so I had the clean it out. Then they coated the inside and outside with a rubber like coating to preserve the tank
Cost 400 bucks
[Re: moparx]
#3064717
08/02/22 06:28 PM
08/02/22 06:28 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Go down to Ace hardware or Home Depo and get the drain cleaner in the black plastic jug, pure lye, comes in its own plastic bag around it. Same thing in those other cleaners (Super Clean) but in lower concentrations. WEAR long gloves designed for this stuff, also glasses. Follow directions on jug. A friend worked in the meat department at A&P and when floor got to gummy from the cuttings he would get Draino and mop the floors. That stuff would eat up street shoes so he used his fishing boots, when done floor was spotless. Don’t get the ‘safe’ stuff, useless, has to say LYE. Also eats rust, paint, scum when put in vat. That's all furniture strippers use, WEAR protective gear!!
[Re: ruderunner]
#3064784
08/02/22 09:45 PM
08/02/22 09:45 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Mustang tank is rear fill, might be a problem loading the bed with a filler neck in the middle. Maybe a flip down tag bracket like some later 70's cars had?
[Re: Twostick]
#3065178
08/04/22 02:19 PM
08/04/22 02:19 PM
Posts: 15,893 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I would do the RC tank now IF you can find one. If not, I agree Simple Green or White Vinegar and pressure wash. I've never tried the Lye etc.
Also, when you re-install, I would add some cushioning where the straps grab the tank the most. These were prone to cracking. That's how I lost mine but fortunately it's a dual tank truck so I'm just running off the in cab tank. Plus, I ran dual exhaust so removing the frame mounted one allowed me room to run the exhaust for the left side, which is a benefit of the RC tank too.
Facts are stubborn things.
[Re: NITROUSN]
#3065263
08/04/22 05:07 PM
08/04/22 05:07 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
While the Ramcharger tank is possible it is not that easily done. There is a lot more needed that does not meet the eye. If you had a doner tank still in the Ramcharger you could get everything and you would also see what I mean. Plus you will have to figure out on how to fill it. I would fix what you got and run it. It's not hard at all. Trickiest part is swapping out crossmembers. Tank fits in the area the spare would normally occupy. The Ramcharger fill neck points to the side, so you could 'move' the fill door back on the bedside, or just bring it up into the bed behind the wheel tub. The rest is just a matter of extending wire and hose. I had a '76 Club Cab I swapped a 35 gal RC tank into. Used just basic hand tools. I did the swap because the original saddle tank had split near the fill. It put weight were it was needed and made running dual exhaust a snap. I ran the fill neck into the bed. I still have the tank and straps if you're interested. You would just have to source the crossmembers. The only possible issue I see with an RC tank in your truck is that your truck is lowered. The RC tank (especially the 35 gal one) does hang down some. You could get a rough idea how far down by holding a strap in place.
John
[Re: topside]
#3066000
08/07/22 09:55 AM
08/07/22 09:55 AM
Posts: 168 San Diego
JP8
San Diego
The mustang tak is almost made to be universal it seems. That's why I am going to use it. My plan is to get one with an EFI pump in-tank, put it between the reara most frame rail section for ballast, and use a "fill through cap" that is frenched flush with the bed floor.
Instagram : @5_points_racing
[Re: JP8]
#3066011
08/07/22 11:04 AM
08/07/22 11:04 AM
cudaman1969
fredericksburg,va
Kinda like the VW bug tanks
