Pressure Washer reccomendation #3063791
07/30/22 06:41 AM
07/30/22 06:41 AM
Greenville, PA
redraptor Offline OP
Greenville, PA
I'm in the market again for a pressure washer. I'm going to stick with an electric in the 2000 psi range. I also want the on/off trigger feature this time which alot of them don't seem to have. 90% of it's usage is for siding and sidewalks. I ran across this Westinghouse unit and thought it was interesting.
https://www.amazon.com/dp/B083B2M9N...d_r=aa995ac0-465f-430c-8343-fa8aeed47f52
Re: Pressure Washer reccomendation [Re: redraptor] #3063802
07/30/22 08:33 AM
07/30/22 08:33 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I know this is not a answer to your question but maybe the electric ones are better since when I bought one some years ago. It left a lot to be desired. I almost immediately bought a gas power and never looked back.
Re: Pressure Washer reccomendation [Re: mopars4ever] #3063839
07/30/22 11:29 AM
07/30/22 11:29 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I agree....had an electric for years and it always disappointed me. Bought this one and never looked back....way better!! I found a sale for about $325
https://www.homedepot.com/p/RYOBI-3...Pressure-Washer-Honda-RY803023/317061018
Re: Pressure Washer reccomendation [Re: redraptor] #3063852
07/30/22 12:16 PM
07/30/22 12:16 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Karcher makes a good one. If you're shopping price this is a good deal https://www.kaercher.com/us/home-garden/electric-pressure-washers/k-2-cck-16023150.html
If you want one that is also a good deal but lots more performance this is well worth it https://www.kaercher.com/us/home-ga...-premium-full-control-plus-13246440.html
Karcher has been making professional pressure washers for decades. We used them for the motocross/supercross/off-road team semi's and support trucks. Good products and not made in China.
Mike
Re: Pressure Washer reccomendation [Re: A12] #3063853
07/30/22 12:26 PM
07/30/22 12:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If you go gas powered they make IMO the best
https://www.kaercher.com/us/home-garden/gas-pressure-washers.html
Re: Pressure Washer reccomendation [Re: A12] #3063897
07/30/22 03:49 PM
07/30/22 03:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I have the larger Karcher Performance Series. Junk. It has 2 soap reservoirs and has never been able to draw anything from either one. Now the last time I used it I got soaked by something breaking inside the wand. Just as much water spraying back and to the side as there was out the nozzle. I called them and they basically said I must be doing something wrong.
whistlingIt's not exactly rocket science, they either work or not. Lesson learned. Buy a real pressure washer without all the fancy looking plastic parts.
Re: Pressure Washer reccomendation [Re: GomangoCuda] #3063905
07/30/22 04:14 PM
07/30/22 04:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quote
Do you have a recommendation? Hard to find pressure washers that don't use plastic wands and parts anymore. I guess the quality has changed, as we still have a 20+ year old Karcher that's working just fine.
Best bet for the OP is to go to the big box store and buy a throw-away electric pressure washer and be done.
Re: Pressure Washer reccomendation [Re: A12] #3064008
07/31/22 02:17 AM
07/31/22 02:17 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
With a warranty.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Pressure Washer reccomendation [Re: BloFish] #3064014
07/31/22 07:13 AM
07/31/22 07:13 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I have a SunJoe, bought it on Amazon. I use it for the fence, deck, cars, and some other things around the house. I'm not a big fan of using it on the siding. I usually use cleaner and garden hose for that. The down side is dragging the cord around and finding a plug where you need to use it. Upside, less maintenance and no gas to go bad. https://snowjoe.com/collections/pressure-washers
Re: Pressure Washer reccomendation [Re: A12] #3064016
07/31/22 07:29 AM
07/31/22 07:29 AM
Greenville, PA
Greenville, PA
Maybe so. This last one I think was a Sam's Club special 20 years ago and has had the piss beat out of it ever since.
Yea, nothing beats a commercial gas powered washer for cleaning concrete.
The motivation for an electric with a cut-off switch is for getting on and off ladders or scaffold or to stop and scrub a spot. I don't know how long you can let any of them idle and I work alone so...
Thanks everyone for your responces!
Re: Pressure Washer reccomendation [Re: redraptor] #3064023
07/31/22 08:27 AM
07/31/22 08:27 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Don't waste you $ on electric or cheap gas ones they will fail in no time. All a pressure washer is is a motor and a pump. Look for used "good" used one. The new "good" ones will not be cheap. And don't get the rotary style pumps stick with the convention piston types. You can get just about anything you need for pressure washing. Usually the good stuff is not supplied with them to keep the price down. A lot of the cheaper pumps will have aluminum pump heads and will corrode. You want brass! I used to repair these years ago so know all about them. Cant go wrong with a 3 or 4 piston pump and gas motor. And you can get replacement parts if it ever fails!
https://www.generalpump.com/
Re: Pressure Washer reccomendation [Re: Moparite] #3064029
07/31/22 10:07 AM
07/31/22 10:07 AM
AZLIVN
SLO-KID Offline
SLO-KID  Offline
AZLIVN
If I were buying one I’d probably go with the Dewalt gas powered unit with the Honda engine. Our lot guys at work probably go through one a year and that thing runs 3-4 hours a day 4 days a week.
Re: Pressure Washer reccomendation [Re: SLO-KID] #3064057
07/31/22 12:00 PM
07/31/22 12:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've got a barely used Hotsy 220v 1 PH with a diesel/ kerosene powered burner. if anyone nearby has a need PM me wink It's Peels paint real nice wink
Re: Pressure Washer reccomendation [Re: Moparite] #3064109
07/31/22 04:15 PM
07/31/22 04:15 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Agree Agree Agree, saving up the coin to buy a new pump $700, 13 hp Honda 5000 psi
Re: Pressure Washer reccomendation [Re: cudaman1969] #3064121
07/31/22 05:14 PM
07/31/22 05:14 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I bought a Blackmax in 2008 used it tons but keep gas in it with Sta_Bil and run it every 30 days for the pump. Of not use pump guard.
It is Honda powered to me thet have one of the best small gas engine's.
Blackmax no longer makes them but makes one almost like it under the brand Ryobi. Thet are owned by the same large company.
My 13hp Honda generator makes over twice the power my old B&S one did and uses half the fuel.
I just serviced yesterday my Snapper Mower, with synthetic oil, gas edger both bought in 2005, weed eater, pressure washer and generator. Most do not do recommended service of oil swaps, air filters ( and oil filters where needed) on equipment.
It is important.
So no matter what gas one you get keeping it serviced will extend the service life.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Pressure Washer reccomendation [Re: 340SIX] #3064280
08/01/22 11:01 AM
08/01/22 11:01 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
If you live in a cold environment don't forget to make sure all the water is out of it before winter hit's or run some RV pipe antifreeze in it. Otherwise It can freeze and damage the pump. Don't run it dry to get the water out either you will melt the seals.
Re: Pressure Washer reccomendation [Re: Moparite] #3064556
08/02/22 06:44 AM
08/02/22 06:44 AM
MI_Custumz Offline
MI_Custumz  Offline
I just turn mine off and squeeze the trigger to get it out of the lines. Then for storage I use pump saver or whatever it's called. Wait until it runs out the end of the nozzle. First use I make sure to run it for a while to make sure all that is out before using it on anything.
Re: Pressure Washer reccomendation [Re: MI_Custumz] #3064631
08/02/22 12:58 PM
08/02/22 12:58 PM
GomangoCuda Offline
GomangoCuda  Offline
Mine is in a heated building that never freezes. Broke anyway. bawling
