Re: TA & AAR Windshield Squirter Parts?
[Re: Alaskan_TA]
#349637
07/08/09 12:55 AM
07/08/09 12:55 AM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Thanks I never thought of that. If it is not to much to ask is there a compleate list of everything that is needed when installling a TA Hood?Like all the buppers that go on the fenders{some have springs ect. I know they used to be just repoped plastic squirters thayt would brake easy even a towel when washing the car would do them in. But heard someone was making new metal ones in limited amounts. My hood was drilled for pins and thats it! Measuements of the locations would also be
[Re: 340SIX]
#349638
07/08/09 07:10 AM
07/08/09 07:10 AM
Posts: 4,115 MD
floyd
MD
FPAP has the squirters: http://www.fpap.com/AAR Cuda & Chall T/A Windshield Squirters Awesome reproduction pair of the unique, metal, LH & RH windshield washer squirters as originally used exclusively on the fiberglass AAR 'Cuda & Challenger T/A hoods of 1970. Use these squirters on any 1970-74 'Cuda or Challenger replacement fiberglass hood to achieve a factory appearance for the treatment of the windshield washer squirters. These squirter assemblies feature correct nozzles (different from RH to LH), stainless steeel lead tube, correct PAL nut, and are 100% fully functioning. Click to enlarge Year Desc. Part # Price Buy -------------------------------------------------------------------------------- 1970 AAR Cuda & Chall T/A Windshield Squirters FPSQ1P $109.00 pr.
[Re: 1_WILD_RT]
#349641
07/09/09 05:39 PM
07/09/09 05:39 PM
Posts: 4,165 Florida
cataclysm80
On the rubber bumpers look at http://www.mcmaster.com Check out page 3700 what they sell may not be perfect but it's close enough that unless someone brings their calipers it would be very convincing... & the one thats closest is less than $10.00 for 100..
I ordered a bag of these to check them out. They measure pretty much the same as Barry's within .002 inch. They appear to have a slightly textured finish instead of a smooth finish. Man, I hadn't realized how small they are! No wonder I never noticed them on a car before.
Here's a pic. Do they look right to you guys?
Tav
[Re: cataclysm80]
#349642
07/09/09 11:46 PM
07/09/09 11:46 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Bill, you keep selling parts like these and I will be you guinea pig any time!!
Here is a picture of my original straps....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#349643
07/09/09 11:50 PM
07/09/09 11:50 PM
Troy
West Coast, CA
.....here is what showed up in the mail today!!!!
[Re: Troy]
#349645
07/09/09 11:58 PM
07/09/09 11:58 PM
Troy
West Coast, CA
These are just right!! They have the same looking head, the clip on the same way as original and they work perfectly!! I must say it's people like Bill and parts like these that makes this hobby so much fun!! A&M HighTech Automotive 6000 Kingsgate Drive. Burlington, KY. 41005 (859) 689-7893 ballphin@fuse.netwww.amhightechauto.comThanks Bill!!
[Re: 340SIX]
#349646
07/12/09 10:55 PM
07/12/09 10:55 PM
cataclysm80
There are two spring loaded bumpers (one on each fender towards the rear)
two rubber bumpers (one on each fender towards the front)
and two threaded hood stops with rubber caps (one on each fender near the radiator support)
These parts are not specific to the N94 TA hood, and would be used on all the steel hood cars also.
Tav
[Re: 340SIX]
#349647
07/12/09 11:05 PM
07/12/09 11:05 PM
cataclysm80
This may not be totally complete, but it's close enough that it should help a lot.
I wrote this for another thread a while back, and this pic is from my own car.
N94 TA Hood
(AAR ‘Cudas use the same N94 code for their hood, but the information below only refers to Challenger TA Hoods.)
Came standard on all Challenger TA cars Also optional after 4-13-70 until the end of 1971 production on 340+4 barrel, 383+4 barrel, 440+4 barrel, 440 Six Pak, & 426 Hemi. (being an RT was not a requirement, but most cars with these engines are RTs)
It was not available with A63 or A46 molding group, M44 hood rear/fender molding, or on SE or A78 formal roof cars due to the rear hood molding. V21 Hood Performance Treatment was also not available on this hood. If the car was ordered with J55 Undercoat/Hood Pad, the hood pad would be deleted.
Cars with this hood option will not come with a hood pop up spring or any hood latch mechanism. As such, J45 hood pins are required with this hood and will use rivets instead of screws to attach the bezel to the hood.
It was always painted organisol, not body color. Along with the hood, you also got the TA hood springs (not the same as AAR), TA windshield squirters (same as AAR), shorter fiberglass hood style radiator to hood seal (same as AAR), longer retainers on front of hood trim (due to fiberglass being thicker than steel), and the appropriate air cleaner to go with your engine/hood combo. If you had one of the optional radios, you were also supposed to get the rear quarter panel mounted antenna (passenger side) like the TA cars had to provide less engine interference with your radio, but so far the few non-T/A examples I’ve heard of came with the regular fender mounted antenna.
Once a production design of this hood was settled on, I don’t know of any variations of it through the end of its availability.
Tav
[Re: TransAm Twins]
#349648
07/12/09 11:23 PM
07/12/09 11:23 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Barry:
The AAR has the clips and screws.
Ken
I have an original squirter set-up from an AAR and it has that clip still on it.
[Re: TransAm Twins]
#349649
08/19/09 09:52 PM
08/19/09 09:52 PM
Posts: 21,428 It's a dry heat
gtx6970
It's a dry heat
Barry:
I was wrong. The T?A has the straps (or at least one of them). The AAR has the clips and screws.
Ken
Bump this back up. Ken, I'm trying to confirm that an AAR requires 3 of these clips , correct ?
[Re: cataclysm80]
#349651
08/21/09 11:31 AM
08/21/09 11:31 AM
gtx6970
It's a dry heat
Are you going to have these AAR clips available also?
Tav
Yes , I just need to confirm the quanities . I had a customer purchase a set at the Nats and he stated AAR's require 3 of the clamps
[Re: cataclysm80]
#349654
08/23/09 08:24 PM
08/23/09 08:24 PM
gtx6970
It's a dry heat
Tav
AAR hood clips with screws
