69 coronet neutral/ reverse harness routing #3063771
07/29/22 11:33 PM
07/29/22 11:33 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Does this harness go up the tunnel or does it go along the rocker to the starter relay? Thanks for your help.
Re: 69 coronet neutral/ reverse harness routing [Re: cudadon] #3063777
07/30/22 01:05 AM
07/30/22 01:05 AM
Cab_Burge Online work
Cab_Burge  Online Work
All the 1969 B body harnesses can remember went from the tranny switch directly p to the relay, probably not long enough to go to the rocker panel and back to the relay work
Re: 69 coronet neutral/ reverse harness routing [Re: Cab_Burge] #3063800
07/30/22 08:29 AM
07/30/22 08:29 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Thanks cab. Do you know if there is a tab or clip of some kind on the tunnel?
There was no harness so I'm trying to make it right.
Thanks, mopar to ya
Re: 69 coronet neutral/ reverse harness routing [Re: cudadon] #3063803
07/30/22 08:35 AM
07/30/22 08:35 AM
Tennessee
CUDASCOTT Offline
CUDASCOTT  Offline
Tennessee
Thanks, mopar to ya
It doesn’t clip to the sheet metal. There’s clips that attach to the trans and ones that go under the bolts that attach the trans to the block.
Re: 69 coronet neutral/ reverse harness routing [Re: CUDASCOTT] #3063806
07/30/22 08:39 AM
07/30/22 08:39 AM
Tennessee
CUDASCOTT Offline
CUDASCOTT  Offline
Tennessee
These are the ones for the bell housing bolts
https://www.classicindustries.com/product/md7121.html
Here’s a pic I swiped from the web for example
Re: 69 coronet neutral/ reverse harness routing [Re: CUDASCOTT] #3063868
07/30/22 01:17 PM
07/30/22 01:17 PM
Midwest
MoparsnMissiles Offline
Midwest
That pic you swiped is my photo that I posted on another website when someone asked about the same question. That's my engine/transmission I built and I just added the black line to indicate approximately where the harness runs. Clips are under the engine/trans mating bolt and tail housing bolt. Not on the body sheet metal. If you look closely you can see the two metal clips that hold the harness in place.
Re: 69 coronet neutral/ reverse harness routing [Re: cudadon] #3063873
07/30/22 01:59 PM
07/30/22 01:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 69 coronet neutral/ reverse harness routing [Re: John_Kunkel] #3063935
07/30/22 06:27 PM
07/30/22 06:27 PM
Midwest
Midwest
Originally Posted by John_Kunkel
Very nice diagram, JK!
Thanks for posting that. up
Re: 69 coronet neutral/ reverse harness routing [Re: CUDASCOTT] #3072075
08/28/22 01:06 PM
08/28/22 01:06 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Thanks that's very helpful.
Re: 69 coronet neutral/ reverse harness routing [Re: John_Kunkel] #3072079
08/28/22 01:17 PM
08/28/22 01:17 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
John Kunkel thanks for the diagram. Do you know where the reverse lights plug in for the harness that goes to the back of the car? This is auto trans. Thanks everyone.
Re: 69 coronet neutral/ reverse harness routing [Re: cudadon] #3083475
10/05/22 08:27 AM
10/05/22 08:27 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
UPDATE on back up light harness.
There is a pigtail connector coming out of the bulkhead connector for windshield wiper motor. Mine was missing. I got it now and all is good. THANKS TO EVERYONE FOR YOUR HELP!
