Stock tach rebuild #3063752
07/29/22 10:35 PM
07/29/22 10:35 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Well it took about 3 months of research on the web to finally break the code!!!!!! I rebuilt my E body stock tach with modern guts!!!
For the first time in 27 years my tachometer is DEAD ACCURATE FROM 0 to 6500 RPM . Total cost was 116 dollars..
EC41F9E9-6917-4849-BD49-8BBB2C0007B5.jpeg18EB333A-7B50-4D2A-B00D-25224D27325B.jpeg6F117A7F-1BB6-4D77-A9AC-196DCF042467.jpeg4C2E994D-FFF8-4A27-911C-42F3714A7C13.jpeg
Re: Stock tach rebuild [Re: ccdave] #3063804
07/30/22 08:36 AM
07/30/22 08:36 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Good show!! What does the back look like?
Re: Stock tach rebuild [Re: 6PakBee] #3063808
07/30/22 08:50 AM
07/30/22 08:50 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Here is a pic of the back
9F2A9D21-81BB-487C-B36A-324A72DEF5FB.jpeg82BBB798-DE0E-42B2-B543-EA1DB0ABF3FF.jpeg98792E79-48CD-48FF-BAF9-743D945B7A96.jpeg
Re: Stock tach rebuild [Re: ccdave] #3063820
07/30/22 09:54 AM
07/30/22 09:54 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Timely thread.....Planning on sending my whole Rally cluster to Tachman this winter.
Re: Stock tach rebuild [Re: usp4u] #3063837
07/30/22 11:22 AM
07/30/22 11:22 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: Stock tach rebuild [Re: Moparite] #3063846
07/30/22 11:45 AM
07/30/22 11:45 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Been there done that with the replacement circuit board. The new circuit board helps but does NOT replace the 50 + years old springs and major components. What I did was replaced EVERYTHING with VDO internals that were produced in 2022.. Makes a HUGE difference as the tach is now dead accurate throughout the entire rpm range.
Re: Stock tach rebuild [Re: ccdave] #3064094
07/31/22 02:50 PM
07/31/22 02:50 PM
moparx Online content
moparx  Online Content
what kind of adhesive did you use to attach the vdo guts to the factory face plate ?
beer
Re: Stock tach rebuild [Re: moparx] #3064119
07/31/22 05:07 PM
07/31/22 05:07 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
I used hot glue to get it positioned then JB Weld epoxy once in place
Re: Stock tach rebuild [Re: ccdave] #3064224
08/01/22 06:39 AM
08/01/22 06:39 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
How are you comparing the gauge reading to the actual rpm? I'm assuming a digital timing light with readout or maybe a second un modified gauge? Looks like the unmodified gauge's sweep to 6500 is different than the rallye gauge's 6500 location?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Stock tach rebuild [Re: usp4u] #3064225
08/01/22 06:48 AM
08/01/22 06:48 AM
BDW Online content
BDW  Online Content
I'd think twice before sending anything to Tachman.
Absolute worse vendor experience I've ever had.
There's a reason he doesn't accept credit cards, you have no recourse for his terrible service.
Re: Stock tach rebuild [Re: A39Coronet] #3064356
08/01/22 01:51 PM
08/01/22 01:51 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
It's all about how I positioned the VDO internals.. If you carefully look at the VDO tach face in the picture you will see that it's identical to the sock E body rallye gauge from 0 to 6500. I'm not claiming to be the first to do this modification. Some very high end shops in California do this exact modification for a lot more $$$ than what it cost me to do it myself.. I tested my tach against a Autometer ultra-lite II 0-10,000 rpm tach.. Dead nuts on from 0 to 6500..
Re: Stock tach rebuild [Re: ccdave] #3064466
08/01/22 07:31 PM
08/01/22 07:31 PM
BDW Online content
BDW  Online Content
Looks good, you should do a detailed write-up to help us out. smile
What is the exact model PN for the donor tach?
Re: Stock tach rebuild [Re: BDW] #3064621
08/02/22 12:23 PM
08/02/22 12:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree Unless of course you're going to start a side business wink
Re: Stock tach rebuild [Re: TJP] #3064663
08/02/22 02:16 PM
08/02/22 02:16 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Now we need a rebuild procedure for the B-body postage stamp tach!! grin
