Jesel Belt drive? #3063432
07/28/22 08:38 PM
07/28/22 08:38 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Question about these....When you put one on an engine, does it affect oil pressure or change engine cooling?
Re: Jesel Belt drive? [Re: Dragula] #3063454
07/28/22 09:50 PM
07/28/22 09:50 PM
gregsdart Online content
gregsdart  Online Content
Can't. What prompted the question?
Re: Jesel Belt drive? [Re: Dragula] #3063458
07/28/22 10:00 PM
07/28/22 10:00 PM
NO, it doesn't affect any thing other than allowing you to use one of their belt drive to drive the camshaft and allow you to adjust the camshaft lobe centers from the front side (radiator side) of the cover wrench Good stuff up scope wrench
Re: Jesel Belt drive? [Re: Cab_Burge] #3063521
07/29/22 10:25 AM
07/29/22 10:25 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
You might need to space water pump away to give clearance
Re: Jesel Belt drive? [Re: Dragula] #3063524
07/29/22 10:32 AM
07/29/22 10:32 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Nope, I can't see how it would. You will have plenty of room for a stock w/p if you run an engine plate but you may need extra clearance or spacers it if you want to run the front mounted, belt driven distributor.
Re: Jesel Belt drive? [Re: mopar_mark] #3063558
07/29/22 11:18 AM
07/29/22 11:18 AM
AndyF Online content
AndyF  Online Content
I don't really understand the question since those things don't have much to do with each other. I run Jesel belt drives or Jesel front drive kits on all of the serious engines I build. Sometimes you have to get creative with the spacers for the water pump, especially when you add the Jesel belt drive distributor. But I've figured it out over the years.
Re: Jesel Belt drive? [Re: mopar_mark] #3063559
07/29/22 11:20 AM
07/29/22 11:20 AM
NC
440Jim Offline
440Jim  Offline
NC
My experience with a 1/4" thick front motor plate was the aluminum water pump housing was just about touching the Jesel center bolt head without gaskets (I use RTV and no WP gaskets). Some water pump housings may need a little (~0.030") grinding or cutting on the back for good clearance.
