Plug recommendation E85
#3063152
07/27/22 10:54 PM
07/27/22 10:54 PM
Posts: 179 California, U.S.A.
Torquemonster440
California, U.S.A.
Looking for a plug recommendation to establish a baseline on a brand new build.. 505ci RB , 11-1 CR Home ported (by me)Promaxx- (same as Sidewinders) 210 cc heads Bullet "street"Solid Roller 254/260 @.050 109 lsa Trick Flow single plane ATM Innovations 950 cfm E85 carb 4.10 gear S60 , RMVB 727 3500 vert ,28"tire Car is 3,600 with me in it 95% street driven I will be running a wideband.
Big question on the plugs.. projected tip ? Non projected ? ... and heat range recommendation. Im a total e85 newb And this is my first stroker build too. Just wanna start off in the right ballpark plug wise if possible. Thanks for any info.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Plug recommendation E85
[Re: Moparite]
#3063223
07/28/22 10:16 AM
07/28/22 10:16 AM
Torquemonster440
California, U.S.A.
Yes, fortunately all of the Chevron stations in my area carry E85. And it's roughly $2.00-$2.50 cheaper/gallon vs CA 91.
[Re: 69dart]
#3063265
07/28/22 11:58 AM
07/28/22 11:58 AM
Torquemonster440
California, U.S.A.
I've ran the Autolite AR3993 and NGK R5671A-9 with success.
I prefer the NGK nowadays as Autolite QC isnt what it once was. I chased an random miss for a couple of races in 2021 - turned out to be a bad new plug. Ok, thanks. I initally bought AR3933's.. but after more research it appears that perhaps that plug may be too cold for a 95% street application like mine. The AR3933's worked well for you on the street?
[Re: Torquemonster440]
#3063280
07/28/22 12:48 PM
07/28/22 12:48 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
My 518 C.I. low deck stroker motor with 15.0 to 1 compression liked Autolite #3934, it did NOT like any colder plugs You can try those colder plugs but don't surprised if the 3934 or 3935 will work better Those Autolite racing plugs have a retracted gap and seem to last forever with our local pump E85
[Re: Cab_Burge]
#3063306
07/28/22 02:08 PM
07/28/22 02:08 PM
Torquemonster440
California, U.S.A.
My 518 C.I. low deck stroker motor with 15.0 to 1 compression liked Autolite #3934, it did NOT like any colder plugs You can try those colder plugs but don't surprised if the 3934 or 3935 will work better Those Autolite racing plugs have a retracted gap and seem to last forever with our local pump E85 Thanks Cab, looks like those 3933's are definitely too cold then.. kinda like I suspected. Always appreciate your info.
[Re: Jeff440sc]
#3063311
07/28/22 02:18 PM
07/28/22 02:18 PM
Torquemonster440
California, U.S.A.
NGK R5671A-7 or a -8 ..... this is a 3/4 reach flat gasket pug.... 7 is hotter than 8 ...9 would be to cold for you... depending on your cam 7 may be a little hot... I run a 8 heat range with 15lbs of boost so I would start with a 7 and read the strap with full timing in. I use to buy e-85 at the pump but found issues with gas stations, E85 can absorb water because of open vents and depending on how fast they replenish the tank, the water will not separate until it reaches a threshold . Next problem is e-85 pump fuels then to be mixed with the cheapest gas they can find . They call that gas "drippings" and its not good gas... the 15 percent cheap drippings was the probable cause of the black gummy residue in the intake manifold which I had experienced. I was told by a manufacture they also use a friction reducer for the gas portion made for transporting the gas in pipe lines which may have contributed to the black gumming, or it was possibly related to the two fuels separating out from one another during the liquid to gas phase in the intake manifold . For these reasons I will only buy a pail or a drum of E85 from Ethanol one to avoid the black gum and water in the fuel.... You have to use a hydrometer to check specific gravity to know if there is water in the alcohol. You have to know what specific gravity spec from the manufacture in order to test for water content. Always keep your tank or fuel seal sealed until ready to race or drive or in a few days with an open vent you will have some water in the fuel because it does suck water from the atmosphere. I learned these things the hard way and hope it helps someone. Best Jeff
Thanks for that heads up, much appreciated. What state are you located in ? Out here in So.Cal the fuel regulations are very strict, which hopefully translates to a more consistent E85 blend ? We shall see.. My neighbor has been running a 13.5-1 408 small block stroker for 2 years on pump E85, when I asked him about his experience he said "Great". ." Just keep the tank full and don't let it sit for longer than a week without driving it". Do you run any type of fuel conditioner ? I've been told the Lucas stuff works well. Thanks for the plug info too.
[Re: Jeff440sc]
#3063582
07/29/22 12:09 PM
07/29/22 12:09 PM
Cab_Burge
i have not had any of the local E85 tested with a good hydrometer for the specific gravity, I do test it for alcohol content and see an increase of alcohol when let it sit in the plastic jugs in the car trailer over the winter. It will go up as high as 88% after sitting long enough My 15.0 to 1 compression S/P bracket race motor didn't seem to notice the difference between fresh E85 out of the local pump or after sitting in the jugs all winter gaining more alcohol content: confused I do have a decent hydrometer that I use to use when I race in NHRA stock classes back when they would check the specific gravity on our race gas, maybe I should use it now on the E85 to see if it changes or not after sitting in the jugs a long time: work:
[Re: Cab_Burge]
#3063710
07/29/22 07:19 PM
07/29/22 07:19 PM
Torquemonster440
California, U.S.A.
i have not had any of the local E85 tested with a good hydrometer for the specific gravity, I do test it for alcohol content and see an increase of alcohol when let it sit in the plastic jugs in the car trailer over the winter. It will go up as high as 88% after sitting long enough My 15.0 to 1 compression S/P bracket race motor didn't seem to notice the difference between fresh E85 out of the local pump or after sitting in the jugs all winter gaining more alcohol content: confused I do have a decent hydrometer that I use to use when I race in NHRA stock classes back when they would check the specific gravity on our race gas, maybe I should use it now on the E85 to see if it changes or not after sitting in the jugs a long time: work: Wow, I'm shocked it's still stable after sitting all winter. Do you add a stabilizer ?
#3063724
07/29/22 08:24 PM
07/29/22 08:24 PM
Cab_Burge
I didn't for several years until I saw some of the Lucas E 85 stabilizer for sale and started using it.: up: I didn't really see a loss of power using the old stuff compared to the new fuel bought locally other than seeing it go from 85% in the fall to between 87 and 89% in the spring when I recheck it I have 5 five gallon plastic jugs and usually had one or two that had fuel in them at the end of the year so I would fill the empty jugs in the spring and mix some of the old fuel with the new fuel to get them closer together on the Ethanol content I also tried adding E98 to the pump fuel to make it E90 but the new E98 wouldn't stay mixed with the pump fuel in the jug I mix it with so I fatten up all four jets by two sizes and didn't see any gain or loss or a difference on the time slip in the 1/8 mile and on the spark plugs with that mix I figure the E98 would stay mix in the fuel cell due to the fuel pump recycling it whenever I had the BG400 pump running I need to figure out which chemical will help keep the E98 mixed with the pump fuel so I can step up the power next year with a power adder and not have to worry about the fuel quality and detonation: work: : devil:
[Re: Cab_Burge]
#3063969
07/30/22 10:14 PM
07/30/22 10:14 PM
Torquemonster440
California, U.S.A.
[quote=Cab_Burge]I didn't for several years until I saw some of the Lucas E 85 stabilizer for sale and started using it.: up: I didn't really see a loss of power using the old stuff compared to the new fuel bought locally other than seeing it go from 85% in the fall to between 87 and 89% in the spring when I recheck it I have 5 five gallon plastic jugs and usually had one or two that had fuel in them at the end of the year so I would fill the empty jugs in the spring and mix some of the old fuel with the new fuel to get them closer together on the Ethanol content I also tried adding E98 to the pump fuel to make it E90 but the new E98 wouldn't stay mixed with the pump fuel in the jug I mix it with so I fatten up all four jets by two sizes and didn't see any gain or loss or a difference on the time slip in the 1/8 mile and on the spark plugs with that mix I figure the E98 would stay mix in the fuel cell due to the fuel pump recycling it whenever I had the BG400 pump running I need to figure out which chemical will help keep the E98 mixed with the pump fuel so I can step up the power next year with a power adder and not have to worry about the fuel quality and detonation: work: : devil: [/quote Quite the Mad Scientist.. .. thanks for all the info and feedback. Dropped the 505 in today. Hope to have it running soon.
