Anyone recognize these fasteners ?? #3063083
07/27/22 06:56 PM
07/27/22 06:56 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I thought I was pretty diligent in bagging and labelling things as I took things apart on my '69RR but I still ended up with some miscellaneous hardware. Anyone recognize these items? The car was not 100% stock so these may not be original pieces.
The castle nuts look to be about 1/2". They could be for tie rod ends. The other things look like locking tabs but they're pretty thick to be bent to lock nuts and I don't recall any bolts that have the flat nor to I recall six of them.
Re: Anyone recognize these fasteners ?? [Re: Stanton] #3063086
07/27/22 07:00 PM
07/27/22 07:00 PM
AndyF Offline
AndyF  Offline
Those castle nuts are common on the front suspension. Could be tie rod ends or the idler arm. Bigger ones are used on the knuckles.
Re: Anyone recognize these fasteners ?? [Re: AndyF] #3063094
07/27/22 07:12 PM
07/27/22 07:12 PM
VA
dragon slayer Offline
VA
The upper control arm adjustable bolt is halfed like those flat pieces. Maybe a type of shim. The washers for control arm cam are made that way. Just guessing.
Re: Anyone recognize these fasteners ?? [Re: dragon slayer] #3063143
07/27/22 10:02 PM
07/27/22 10:02 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
These would only take a 1/4 or 5/16 bolt.
Re: Anyone recognize these fasteners ?? [Re: Stanton] #3063180
07/28/22 01:50 AM
07/28/22 01:50 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
The lower picture looks like locking tabs for Hurst 4-speed shift rods when the rod ends back by the shifter are threaded for nuts. The D shaped hole makes them easy to recognize. That setup was nice because you could really dial out any slop where the rod adjuster connected to the shifter 1-2 and 3-4 plates. Once you tightened the nut to eliminate all play without binding, you folded over the locking tabs on that shim. Hurst discontinued them back at the turn of the century and replacements became scarce. I eventually had to switch back to the goofy clips and bushings when I had used up all of my replacement shim kits.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Anyone recognize these fasteners ?? [Re: rumblefish72] #3063206
07/28/22 08:29 AM
07/28/22 08:29 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
I was thinking that too. If that's the case, I would have swapped them for nylocs. I'll have to dig the shifter out and have a look.
Re: Anyone recognize these fasteners ?? [Re: Stanton] #3063244
07/28/22 11:08 AM
07/28/22 11:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by Stanton
Quote
Can you post a picture of the shifter when you find it , I've never seen what is being talked about .
Re: Anyone recognize these fasteners ?? [Re: JohnRR] #3063262
07/28/22 11:49 AM
07/28/22 11:49 AM
This is the only picture I have from that setup. Unfortunately, you need a detail closeup picture from directly behind the shifter body to see how the nuts and bend-over tabs lock the shifter rod adjusters to the shifting arms hanging out the bottom of the shifter.
