How’s this combo sound for cruising
#3062847
07/26/22 08:36 PM
07/26/22 08:36 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
The current combo is
383 727. 8.75 with a 355 gear and 26.8 inch tires
I’d like to run a gearvendor unit to lower my 65-70 mph cruise rpm by 400 or 500 whatever it is
I’m also running a 2500 stall converter now. The cam is a 230/236 comp grind that has issues wanting to push through the brakes Hence the upgrade to the 2400-2500 stall converter
What’s everyone’s opinion. Will the combo work?
I’d like to be 2500 rpm as close to 70 as possible
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: How’s this combo sound for cruising
[Re: gremlinsteve]
#3063019
07/27/22 02:03 PM
07/27/22 02:03 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
[Re: mgoblue9798]
#3063034
07/27/22 03:03 PM
07/27/22 03:03 PM
gremlinsteve
houston texas
Unless you are running a lockup style 727, you need to consider what your cruise rpm will be v/s the converter rpm. If cruise is lower than the converter it might be a problem. You would need to discuss it with your converter manufacturer. true i have a cheap hughs 2400 converter i assume that it "should" be ok for me i like fti and pro torque myself i
[Re: Cab_Burge]
#3063035
07/27/22 03:04 PM
07/27/22 03:04 PM
gremlinsteve
houston texas
thanks for your insight again. i appreciate it tremendously
[Re: TJP]
#3063215
07/28/22 09:42 AM
07/28/22 09:42 AM
Posts: 12,071 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Finding and buying a good torque converter can be very challenging, especially on the street The understatement of the decade It took me 3 tries to get happy with my converter. And I have to pull the engine and tranny to change the converter. What a chore.
Master, again and still
[Re: moparx]
#3063344
07/28/22 03:38 PM
07/28/22 03:38 PM
gremlinsteve
houston texas
lol i remember that company
