Re: Big block 727 #'s?
[Re: 6bblgt]
#3062551
07/25/22 07:24 PM
07/25/22 07:24 PM
Posts: 2,046 ky.
kenworth_goose
ky.
built late '76 for a 400
should be a partial VIN stamped on the other side of bellhousing - no Big Block Road Runners in '77 Thank you. Seller said 69 Road Runner and I'm not a big #'s guy. I just wanted to find out if it was needed or wanted for a particular car.
[Re: kenworth_goose]
#3062583
07/25/22 10:02 PM
07/25/22 10:02 PM
Posts: 15,323 Omaha Ne
TJP
Omaha Ne
should be a partial VIN stamped on the other side of bellhousing - no Big Block Road Runners in '77 Thank you. Seller said 69 Road Runner and I'm not a big #'s guy. I just wanted to find out if it was needed or wanted for a particular car. In 20 years or less they'll be restoring them so if you hang onto it In 40 years it'll be I've got a numbers matching gas guzzler from 1977 but you ca't tell anyone if i show it to you or God forbid start it up. probably have to jump start it with his EV LOL
[Re: moparx]
#3062821
07/26/22 06:37 PM
07/26/22 06:37 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
76 is a good year for 727s there getting near the end of the run & have the most updated components if it's all original & hasn't had parts swapped around, I know there's something that's not quite as good/strong as earlier ones but don't recall what.
