old Optima batteries #3062082
07/24/22 01:03 PM
07/24/22 01:03 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Any way to bring these back from the dead ?
Can't add more acid, they are sealed.
Re: old Optima batteries [Re: hemienvy] #3062083
07/24/22 01:08 PM
07/24/22 01:08 PM
moparx Offline
moparx  Offline
lead acid or gel type ?
there is a guy on the u-tube that claims to be able to bring back any battery ever made, but i'm not giving him $40.00 [or whatever he wants] to find out how.
beer
Re: old Optima batteries [Re: moparx] #3062086
07/24/22 01:25 PM
07/24/22 01:25 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I think they are gel. AGM ?
Re: old Optima batteries [Re: hemienvy] #3062111
07/24/22 02:45 PM
07/24/22 02:45 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Here is what I was told to do... Take a Lead Acid battery and run jumper cables from the LA to the Optima (pos to pos) and (neg to neg) then put a battery charger on the LA battery.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: old Optima batteries [Re: W.I.N. Racing] #3062113
07/24/22 02:53 PM
07/24/22 02:53 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
W.I.N., I'll try that but I don't understand.......
Re: old Optima batteries [Re: W.I.N. Racing] #3062130
07/24/22 03:23 PM
07/24/22 03:23 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
This worked for me too except I used another fully charged Optima
Re: old Optima batteries [Re: DavidDean] #3062131
07/24/22 03:25 PM
07/24/22 03:25 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Just hook up the batteries like you're trying to jump the dead one. Then charge the good battery. Be sure the polarity is correct
Re: old Optima batteries [Re: hemienvy] #3062159
07/24/22 05:04 PM
07/24/22 05:04 PM
Byron, NY
Byron, NY
The resistance in a AGM battery is so low that the charger doesn't see a load. Make sure you start with a fully charged LA battery...
'60 Willys CJ5
Re: old Optima batteries [Re: W.I.N. Racing] #3062172
07/24/22 06:05 PM
07/24/22 06:05 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK I have it hooked up now, the lead battery was maybe a bit low, not too bad.
I have a little Optima Digital 400 charger.
Re: old Optima batteries [Re: hemienvy] #3062185
07/24/22 06:56 PM
07/24/22 06:56 PM
Byron, NY
Byron, NY
I found this for you
Charging an optima battery
'60 Willys CJ5
Re: old Optima batteries [Re: W.I.N. Racing] #3062189
07/24/22 07:13 PM
07/24/22 07:13 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Well that was very good. I see I'm doing it wrong, but now I have a better idea.
Re: old Optima batteries [Re: W.I.N. Racing] #3062586
07/25/22 10:17 PM
07/25/22 10:17 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Thanks for that
Wish i had known of this before trading in a 'dead' 15 yr. old red Optima core for a new Optima last year. I would have bought the new Optima anyway, but could have given them a different core. Would have been worth a try to recharge it.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: old Optima batteries [Re: W.I.N. Racing] #3062591
07/25/22 10:43 PM
07/25/22 10:43 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Haven't watched the vid yet, but I have an OLD Optima that's been sitting around for 10+ years. I also have a new one I purchased w/in the last year to replace it, since I ASSumed the old one was nothing but scrap now.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: old Optima batteries [Re: W.I.N. Racing] #3062616
07/26/22 08:07 AM
07/26/22 08:07 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Have done this before, myself. It works.
Re: old Optima batteries [Re: Brad_Haak] #3062645
07/26/22 10:19 AM
07/26/22 10:19 AM
AndyF Offline
AndyF  Offline
The video is good. They recover a 20 year old Optima by using another battery as a storage cell. The trick requires a battery charger with a 10 amp setting. Trickle charger doesn't work and neither does the super blast type of charger.
Re: old Optima batteries [Re: AndyF] #3062710
07/26/22 12:15 PM
07/26/22 12:15 PM
Byron, NY
Byron, NY
As an aside... I have switched to Snyder motorsports batteries, smaller (by weight and size) and less expensive. twocents
'60 Willys CJ5
Re: old Optima batteries [Re: W.I.N. Racing] #3062874
07/26/22 10:55 PM
07/26/22 10:55 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The Ctek chargers do a really good job on the agm's, or any lead acid battery for that matter. I bought a special agm charger and it often will charge an agm for about and hour, then say bad battery on the readout.I put the Ctek on it overnight on the recond setting, and the battery is back to life the next day.
Re: old Optima batteries [Re: Uberpube] #3062887
07/27/22 12:40 AM
07/27/22 12:40 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I've been working on this one Optima for a couple days now. It was getting a bit warm during charging.
The Schumacher charger never did reach 10 amps charging, this is with a another good battery in parallel.
It went from about 4 amps to 7 amps. This evening when I unhooked everything, the Optima read 10 volts.
I'm going to check voltage in the morning to see if it drops. The charger was getting pretty warm too.
I'm going to keep going to see if I can get the Optima up to 12.7 volts. I don't want to keep the charger on
in the garage overnight unattended, for safety. The system does appear to be working though, albeit slow.
Re: old Optima batteries [Re: hemienvy] #3062897
07/27/22 06:30 AM
07/27/22 06:30 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Next time you have it charging and it gets warm feel all the cylinders, if one is cold then you likely won't get it over 10.5v or so due to a dead cell.
68 Barracuda Formula S 340
Re: old Optima batteries [Re: Bad340fish] #3063020
07/27/22 02:10 PM
07/27/22 02:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
i bought two of the X3 brand batteries, neither one would hold a charge while setting during the winter, I used their special charger also, but they didn't hold up well while sitting whiney That dang super expensive specail charger work once and quit rant puke down
I'll try using another standard battery in parallel to see if they will respond and take a charge that way luck
I'll post my results on here next week luck
