Stall question #3061991
07/24/22 01:55 AM
07/24/22 01:55 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
I’ve got a gen 3 Hemi 6.4 engine with an a518 46rh behind it in my 70’s Satellite. The 46rh has overdrive and lockup.
When coming to a full stop the engine wants to stall. Then I throw the trans in Neutral and after the full stop I put it back into drive.
The 3 pin connector is hooked up but the Patc vacuum switches aren’t. The vehicle speed sensor isn’t used.
What can be wrong?
Re: Stall question [Re: dickdale] #3062010
07/24/22 06:48 AM
07/24/22 06:48 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
It sounds like you are staying in lock up.Check your wiring and hook up the switches.
https://transmissioncenter.net/shop/727-to-518-transmission-swap-information/
Re: Stall question [Re: Moparite] #3062027
07/24/22 09:38 AM
07/24/22 09:38 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Agree, sounds like the car doesn't know your coming to a stop.
Re: Stall question [Re: dickdale] #3062136
07/24/22 03:34 PM
07/24/22 03:34 PM
i put a lockup switch on my first Cummins diesel powered pickup truck, 1998 1/2 24 vavle with the weak automatic, if I didn't turn the switch off when stopping it would drag the motor RPM way down and make me afraid to not unlock the converter work shruggy
Sounds like you're having the same thing scope wrench up
Re: Stall question [Re: dickdale] #3062148
07/24/22 04:28 PM
07/24/22 04:28 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Simple solution is to use a toggle switch(es) to control lock up and o/d. Could use the same switch for both wired as a ground interrupt if you do not care about running them independently from one another.
Re: Stall question [Re: dickdale] #3062149
07/24/22 04:33 PM
07/24/22 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The fluid that is used to lockup the converter originates at the 1-2 shift valve...so there can be no lockup until after the 1-2 upshift occurs.
In normal operation, as the vehicle slows to a stop, the trans downshifts directly from 3rd to 1st bypassing 2nd. If there is a governor problem and the trans doesn't downshift to 1st just before the stop, the converter can remain locked up. Shifting to Neutral restarts the sequence.
Other problems could be the sealing rings on the input shaft allowing line pressure to lockup the converter un-commanded.
