Aluminum Driveshaft?
#3061701
07/22/22 08:00 PM
07/22/22 08:00 PM
Posts: 10,038 MN
JERICOGTX
MN
Who makes a good aluminum driveshaft, at a reasonable price, and not take 6 months to get?
Thanks.
Jeff
69 GTX
68 Road Runner
Re: Aluminum Driveshaft?
[Re: Clanton]
#3061745
07/22/22 11:20 PM
07/22/22 11:20 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Minnesota Driveline in St. Cloud will make you one.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: CSK]
#3061882
07/23/22 04:01 PM
07/23/22 04:01 PM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
It had damm well better be polished to a high luster when installed
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: moparx]
#3062176
07/24/22 06:15 PM
07/24/22 06:15 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
X4 On Mark Williams you wont be sorry....
[Re: Hemi_Joel]
#3062358
07/25/22 11:11 AM
07/25/22 11:11 AM
Posts: 10,038 MN
JERICOGTX
MN
Minnesota Driveline in St. Cloud will make you one. I called them. They wanted as much as Mark Williams to make one...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3062375
07/25/22 11:56 AM
07/25/22 11:56 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Minnesota Driveline in St. Cloud will make you one. I called them. They wanted as much as Mark Williams to make one... I think I paid 625$ for mine in Grafton.I had the yoke already.
[Re: Clanton]
#3062382
07/25/22 12:19 PM
07/25/22 12:19 PM
Posts: 10,038 MN
JERICOGTX
MN
Minnesota Driveline in St. Cloud will make you one. I called them. They wanted as much as Mark Williams to make one... I think I paid 625$ for mine in Grafton.I had the yoke already. I was quoted $900, and using my yoke.
69 GTX
68 Road Runner
[Re: bigdad]
#3062482
07/25/22 03:40 PM
07/25/22 03:40 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
I went through drive shaft hell, Mark Williams has the correct ballance machine to spin it to the correct RPM, I had a Strange shaft & fought a vibration, also 2 other ones built locally to me, turns out they can only spin it 500 rpm, got one from MW & problem solved, $1400 dollars worth of JUNK drive shafts, GRRRRRRRR
[Re: JERICOGTX]
#3062535
07/25/22 06:26 PM
07/25/22 06:26 PM
Hemi_Joel
Minnesota
Minnesota Driveline in St. Cloud will make you one. I called them. They wanted as much as Mark Williams to make one... I think I paid 625$ for mine in Grafton.I had the yoke already. I was quoted $900, and using my yoke. During the winter, they built a 5" aluminum, about 6 feet long for my truck for $700 something. Maybe they went up, or perhaps they use better more expensive yokes in a race car.
