Cuda suspension parts #3061349
07/21/22 01:45 PM
07/21/22 01:45 PM
Wisconsin
71duster414 Offline OP
Wisconsin
I have a 71 cuda that I'm restoring and would like all the correct parts pieces and bushings for the front and rear suspension. Who in the hobby might have this stuff? For instance factory ball joint boots or replicas of originals.
Thanks!
hoffmanhhr@gmail.com
Re: Cuda suspension parts [Re: 71duster414] #3061449
07/21/22 04:54 PM
07/21/22 04:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Local parts store, NAPA, Rock Auto, etc.
Re: Cuda suspension parts [Re: 71duster414] #3061475
07/21/22 06:39 PM
07/21/22 06:39 PM
New Jersey Bada Bing
bremotorsports Offline
I have an extensive inventory of top quality items for both front and rear suspension.
You can review the items on my website at: www.billrolikenterprises.com Your needs can be found primarily in Group 2 and Group 17 of the site index.
bremotorsports@verizon.net
201-394-5533 Cell/Text
Bill Rolik
Re: Cuda suspension parts [Re: bremotorsports] #3061482
07/21/22 07:14 PM
07/21/22 07:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just noticed your mention of factory ball joint boots.
I don't believe any new tie rods are manufactured to take the original snap on boots that have a metal ring molded into them.
Most all brands new lower ball joint boots are snap on. But I think the profile of the originals are different. Not as large and rounds as current
Seems like new brands upper ball joints are either square profile metal snap with molded over rubber or exposed cad swaged over end metal snap. Not sure which is similar to production line parts.
Otherwise NOS will get you very close.
If you are looking at this level of detail, I assume the rest of the more noticeable parts of the car will be to an even higher level of detail.
