The 541 is headed to the dyno! Results are in!
#3060109
07/18/22 08:23 AM
07/18/22 08:23 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I finally got the 541 all buttoned up and ready to dyno. Moparts member sr440 is kind enough to let me make a mess on his dyno tomorrow.
So, what does the brain trust think? I'm pretty sure I got the cam and all the pistons in there so it just might run.
4.50 crank 4.375 bore 10.5 compression Edelbrock performer heads with a full CNC job Hydraulic roller 235/241 cam with 589/571 lift 112 LSA Comp roller rockers Old Weiand tunnel ram converted to front facing port injected intake 1700 cfm throttle body 2" dyno headers will be replaced with my 1-7/8" headers when it goes in the car.Don't want to smoke the ceramic on the dyno.
The idea behind this thing was to have an oversized cruiser with stupid amounts of torque with HP being whatever it wants to do.
What's your guess on power?
Re: The 541 is headed to the dyno! Any guesses?
[Re: Twostick]
#3060135
07/18/22 10:56 AM
07/18/22 10:56 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My take on it is....... The Weiand TR is too small to support 541” at any kind of higher rpm, so I’m expecting to see a pretty big TQ number, then the HP will peak pretty early. As a result of the early peak the HP number won’t be all that big. I’m thinking the TQ/HP numbers will end up pretty lopsided, towards the TQ end of things.
To throw some numbers out there(which will be a total “WAG”), 660-670ft/lb, 550-560hp.
In order to know how the basic long block combo compares to “the rest of the world”, it would need to be tested with a “known quantity” induction on it.
[Re: fast68plymouth]
#3060168
07/18/22 12:02 PM
07/18/22 12:02 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I'm going to say vey close to 700 ish TQ very early & 520 to 540 hp
#3060215
07/18/22 12:48 PM
07/18/22 12:48 PM
feets
Senior Management
Senior Management
Irving, TX
In order to know how the basic long block combo compares to “the rest of the world”, it would need to be tested with a “known quantity” induction on it. The intent of the build was to make silly amounts of torque over a usable range. HP was never a concern. It was going to fall into the Rolls Royce range of "sufficient". This thing needs to pull down the highway at 1700 rpm and still have a full normal rpm range. It's an unusual build for sure.
[Re: feets]
#3060218
07/18/22 12:56 PM
07/18/22 12:56 PM
fast68plymouth
So. Burlington, Vt.
Mechanically, the upper limit of the usable rpm range will likely be determined by the valvetrain.........although the hp peak should occur well before that.
#3060248
07/18/22 02:18 PM
07/18/22 02:18 PM
feets
Senior Management
Senior Management
Irving, TX
If it peaks between 5200 and 5500 I'll call it a proper job.
The Imperial needs a high torque low rpm engine but I didn't want a tractor motor.
[Re: feets]
#3060264
07/18/22 03:25 PM
07/18/22 03:25 PM
Posts: 31,069 Oregon
AndyF
The Imperial needs a high torque low rpm engine but I didn't want a tractor motor. Cam is small so that will restrict the power but you should have great torque. I'm going with 650 torque and 525 hp as a guess. Hopefully it starts, runs good and doesn't leak. If it does those three then it is a successful dyno day. Fine tuning can always take place down the road. Are you confident of the EFI tune at this point or will you need to dial in that tune on the dyno?
[Re: feets]
#3060288
07/18/22 04:52 PM
07/18/22 04:52 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
No guesses, but Good luck with it, hope it runs well for you.
Rich H.
Esse Quam Videri
#3060345
07/18/22 07:56 PM
07/18/22 07:56 PM
feets
Senior Management
Senior Management
Irving, TX
You should have your answer in about 24hrs It's your cam so it's all your fault anyway. When I've discussed the build with other engine builders they like the combo. People have to understand that it's not a horsepower build. This thing needs to have a strong vacuum signal, be happy lugging a 5300 lb car down the highway at 1800 rpm, idle fairly smooth, and make absurd torque everywhere in the rev range. I'm pretty sure it'll do all that.
[Re: AndyF]
#3060346
07/18/22 07:57 PM
07/18/22 07:57 PM
feets
Senior Management
Senior Management
Irving, TX
The Imperial needs a high torque low rpm engine but I didn't want a tractor motor. Cam is small so that will restrict the power but you should have great torque. I'm going with 650 torque and 525 hp as a guess. Hopefully it starts, runs good and doesn't leak. If it does those three then it is a successful dyno day. Fine tuning can always take place down the road. Are you confident of the EFI tune at this point or will you need to dial in that tune on the dyno? I'd be happy with that torque and maybe a wee bit more hp. Maybe 540? Rich Nedbal from FastmanEFI.com will be remoting in to build the tune.
[Re: LA360]
#3060370
07/18/22 08:36 PM
07/18/22 08:36 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There is probably some power in opening up the ports in that tunnelram. The question is, how will it affect the torque you prize. I like your build. At first I thought it might be limited to low 500 hp teritory. But it might surprise us. I will guess 560 hp. max torque 660 at 3400? No matter what, you are going to love the way this deal runs!
[Re: feets]
#3060557
07/19/22 12:56 PM
07/19/22 12:56 PM
ZIPPY
S.E. Michigan
Ringer alert
Rich H.
Esse Quam Videri
