timing marks , whats there value? #306000
05/02/09 09:24 PM
05/02/09 09:24 PM
minnesota, USA
greenfire Offline OP
minnesota, USA
hi just trying to determine the value of the timing marks, what is the value of each mark?5,or 10 degrees?
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: timing marks , whats there value? *DELETED* [Re: greenfire] #306001
05/02/09 09:32 PM
05/02/09 09:32 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Post deleted by MAVERICKSHEMI
Re: timing marks , whats there value? [Re: MAVERICKSHEMI] #306002
05/02/09 09:34 PM
05/02/09 09:34 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
5 degrees on mine.
Re: timing marks , whats there value? [Re: rss] #306003
05/02/09 09:36 PM
05/02/09 09:36 PM
minnesota, USA
minnesota, USA
this is on a 74 318
Re: timing marks , whats there value? [Re: greenfire] #306004
05/02/09 09:37 PM
05/02/09 09:37 PM
Az
Crizila Offline
Crizila  Offline
Az
5 degrees in your pic
Fastest 300
Re: timing marks , whats there value? [Re: Crizila] #306005
05/02/09 11:14 PM
05/02/09 11:14 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
The zero in the middle is tdc(obviously)
The 0's on each side are 10(the 1 is covered in grime) so yes the marks inbetween are 5.
Re: timing marks , whats there value? [Re: dave571] #306006
05/02/09 11:43 PM
05/02/09 11:43 PM
minnesota, USA
minnesota, USA
thanks, the p.o had the initial timing set at 0 tdc, i set the timing at 10 degrees btdc and noticed improvement, getting late so i will try 15degrees btdc in the morning and see what happens, thanks again folks
Re: timing marks , whats there value? [Re: greenfire] #306007
05/02/09 11:51 PM
05/02/09 11:51 PM
Plug your vac line & see what you have for total. Are the orig springs in the dist(1 light & 1 heavy w long loop on one end)?. Stock 74 318?
Re: timing marks , whats there value? [Re: RapidRobert] #306008
05/03/09 12:02 AM
05/03/09 12:02 AM
minnesota, USA
minnesota, USA
my timing light is old, not dial back, and i didnt pull the dist cap, was getting dark, i will check the dist springs tomorrow. i did disconnect the vacuum line from the advance on the dist when i checked the timing and i did plug the line too. how much difference should there be in the readings with the vacuum line attached/disconnected at idle?
Re: timing marks , whats there value? [Re: greenfire] #306009
05/03/09 12:10 AM
05/03/09 12:10 AM
Ported vac would have zero(or near zero) vac at idle. Stock 74 318?. Make a new mark on your dampener 2&1/4" clockwise from your original TDC mark & that is 35.5 degrees.
Re: timing marks , whats there value? [Re: RapidRobert] #306010
05/03/09 12:14 AM
05/03/09 12:14 AM
minnesota, USA
minnesota, USA
stock 74 318 block and heads, eddy performer 4bbl intake and eddy 600 cmf 4bbl carb. no intake leaks, new hoses and vacuum lines too.i have the vacuum advance hooked up to the timed vacuum port on the carb also. the distributer appears to be stock/original as well.
Re: timing marks , whats there value? [Re: greenfire] #306011
05/03/09 12:35 AM
05/03/09 12:35 AM
What cam. I would 1st see what your total is(where it quits advancing & vac adv plugged) & if your springs are oe you might get the MP light spring kit(its cheap) & sub in ONE of them to replace the stock heavy spring w the long loop on one end then set your total(as in above) to 35 & see what that lets your initial fall at & post that for a start & if it EVER pings back it down & the curve(slot length ) will probably need to be optimized also. You have no dialback so .0632683" around the circumference of the dampener is 1 degree so with some math and a 2-3" micrometer cut/measure a piece of wire to mark your dampener to get some readings.
Re: timing marks , whats there value? [Re: RapidRobert] #306012
05/03/09 04:26 PM
05/03/09 04:26 PM
minnesota, USA
minnesota, USA
stock cam, well i hooked up a tach and disconnected the vac line and plugged vac line, made a new timing mark on the balancer as per instruction to give me a 35 degree mark. brought the motor up to about 2800 rpm's and then adjusted the dist till the new mark was at 0 tdc. snugged down the dist clamp and checked my initial timing and that was at about 11-12 degrees after tdc. runns good and i was able to break the tires loose and no pinging.
Re: timing marks , whats there value? [Re: greenfire] #306013
05/03/09 04:30 PM
05/03/09 04:30 PM
11-12 before TDC?
Re: timing marks , whats there value? [Re: RapidRobert] #306014
05/03/09 06:09 PM
05/03/09 06:09 PM
minnesota, USA
minnesota, USA
oops, my bad, i read my new timing mark instead of the initial timing mark. my initial timing mark reads 15 degrees btdc. works good.and if i need to, i can always back it down a tad. thanks robert you were a great help
