my 69 pad attaches with a screw at the rear, which is hidden by the seat back, and the two clips shown, which go into holes that are approximately 1/4" [i didn't measure them].
i would think your 70 would be the same, but as your picture clearly shows, there are no corresponding holes in your inner framework for those clips.
does the pad fit, along with the rear panels ? [tried by removing the clips to just see if it fits]
if so, and you are happy with the repop pads, you will have to carefully measure where the clips are and drill the corresponding holes in the inner framework.
if i'm full of it [
], at least this will be a bump for ya, and more knowledgeable folks will chime in.
