torsion bar & leaf spring paint daubs #3059899
07/17/22 12:15 PM
07/17/22 12:15 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Working on my A12 suspension:
Whats the recommended color (& source) to be used on the torsion bars (dark gold-ish/brown).
Same for the leaf springs. Right side original shows, blue/white, but its pretty faint.
Chris
Re: torsion bar & leaf spring paint daubs [Re: cdp] #3060070
07/18/22 02:19 AM
07/18/22 02:19 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The probability that anybody knows the real answers is pretty much zero.
In the case of my torsion bars, the original factory paint and factory paint daubs are still plenty good enough as-is for a thorough restoration.
All the photos I've seen and the paint daubs on my own leaf springs indicate these were made with latex paint in pastel house paint colors.
Go to Lowe's and buy two half pint sample colors of exterior grade for less than $10. Pick your colors from the dozens of brochures on display.
In my case, the colors looked to me like khaki tan and aqua, which translated to Sherwin Williams Balanced Beige and Transparent Pool. But there were numerous other choices that would have worked just as well.
Be sure to apply the latex before the RPM wax. Oops.
IMG_2618.jpg8378075e.jpg8378116-Picture056small.jpg17 Rear Springs. paint daubs under black paint2.JPG
Re: torsion bar & leaf spring paint daubs [Re: kentj340] #3060128
07/18/22 10:15 AM
07/18/22 10:15 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just went to my local craft store that has a big model paint selection. I matched up the colors as best as I could. When I got home, I mixed a few together to come up with a custom mix that looked good to my eye. You can try dipping the ends of the leaf springs in EvapoRust. That might get the colors to come out a little nicer. I just dipped mine for a little while and these colors showed up. The leaves were very rusty with no paint marks showing before the dip.
