Re: What will it run 410 stroker 71 Duster.
[Re: FurryStump]
#3058573
07/12/22 01:28 PM
07/12/22 01:28 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
Is it spinning? 60’ is soft. 4:10 might help a bunch. Mine is a low gearset 904, but I run a 26” tire with 4:10’s, with a 9.5” ptc converter that slips 3-4% at the stripe. If flashes to 3500 rpm. Crosses at 6500-6700 rpm using the same crank. I have 1000’s of runs on it and dragweek and 60,000 street miles. It has been balanced to 1/2 a gram by a real old, very picky guy. Oh, with that hp in a sorted out combo you with be in roll bar territory. Low 11’s I didn’t feel any spin, honestly it seemed to be dead hooking. The track was very well preped because they had their Friday heads up series the night before. I think the converter is holding me back, it seems to start pushing through the brakes ( I’m foot braking it) around 2000-2200 rpm. I had my revlimiter set at 6300, plan to bump that to 6500 or high next time out, it was either starting to bounce off of it or float valves around the 1000-1100 ft mark.
[Re: moparjoe360.4]
#3058619
07/12/22 03:31 PM
07/12/22 03:31 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I had my revlimiter set at 6300, plan to bump that to 6500 or high next time out, it was either starting to bounce off of it or float valves around the 1000-1100 ft mark. If it’s some type of hyd cam, it’s certainly possible(and not uncommon) to experience valvetrain control issues before ever getting to 6300. I usually sneak up on the rpm on the dyno to see if I can determine where the problem starts........ then you know.
[Re: fast68plymouth]
#3058652
07/12/22 05:57 PM
07/12/22 05:57 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
I had my revlimiter set at 6300, plan to bump that to 6500 or high next time out, it was either starting to bounce off of it or float valves around the 1000-1100 ft mark. If it’s some type of hyd cam, it’s certainly possible(and not uncommon) to experience valvetrain control issues before ever getting to 6300. I usually sneak up on the rpm on the dyno to see if I can determine where the problem starts........ then you know. It’s a .508/292 Mopar purpleshaft cam,with Smith Bros push rods, Harland Sharp 1.5 rockers, I feel like the week point might be the valve springs themselves, it has whatever Areohead (Indy cyl head) installed on them, they were supposed to be good to .509 lift. We were only pulling it to 6000rpm on the dyno and never went past that.
[Re: moparjoe360.4]
#3058701
07/12/22 08:22 PM
07/12/22 08:22 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I had my revlimiter set at 6300, plan to bump that to 6500 or high next time out, it was either starting to bounce off of it or float valves around the 1000-1100 ft mark. If it’s some type of hyd cam, it’s certainly possible(and not uncommon) to experience valvetrain control issues before ever getting to 6300. I usually sneak up on the rpm on the dyno to see if I can determine where the problem starts........ then you know. It’s a .508/292 Mopar purpleshaft cam,with Smith Bros push rods, Harland Sharp 1.5 rockers, I feel like the week point might be the valve springs themselves, it has whatever Areohead (Indy cyl head) installed on them, they were supposed to be good to .509 lift. We were only pulling it to 6000rpm on the dyno and never went past that. You don’t need to go past 6k with a stroker like yours to get it to ET extremely well. I shifted my stock stroke 360 at 6k, it went 11.20’s. My stroker has been 10.68 now, at 3350 pounds, I shift it at 6300, if I shifted it at 6 it wouldn’t slow down much at all. I didn’t see what heads you are using, what are they? The convertor is most definitely a liability regards making more optimal ET Switching to 4.10gears from 4.30’s would be a waste of time. It’s about 250 rpm at the stripe difference. And ( assuming it doesn’t hook, it probably does) it very likely wouldn’t hook with 4.10’s either That dyno number is enough to run close to a second quicker than you are. Post exactly the entire combo, would enjoy looking at it and making recommendations Pretty car, btw
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3058923
07/13/22 02:59 PM
07/13/22 02:59 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
I’m running 974 casting iron heads that I ported and polished myself, I got the stroker kit from scat, they balanced it, it has icon flat top pistons and cometic MLS head gasket (.040 thickness if I remember correctly) it has about 11-1 comp eddy RPM Airgap , proform 750 dp, Holley blue pump, 8an fuel lines, MSD Digital 6AL . I think that basically covers the combo between what I mentioned before and this. I Thanks, my dad and I have completely re built it in his garage, the only thin we farmed out was the machine work on the engine. I built the entire drivetrain and he did the body and paint work (about 30-40% of the gold is original paint)
[Re: moparjoe360.4]
#3058929
07/13/22 03:13 PM
07/13/22 03:13 PM
B3422W5
Portage,michigan
I’m running 974 casting iron heads that I ported and polished myself, I got the stroker kit from scat, they balanced it, it has icon flat top pistons and cometic MLS head gasket (.040 thickness if I remember correctly) it has about 11-1 comp eddy RPM Airgap , proform 750 dp, Holley blue pump, 8an fuel lines, MSD Digital 6AL . I think that basically covers the combo between what I mentioned before and this. I Thanks, my dad and I have completely re built it in his garage, the only thin we farmed out was the machine work on the engine. I built the entire drivetrain and he did the body and paint work (about 30-40% of the gold is original paint) Sweet. if the heads are pretty good, the car has a bunch more in it, especially with a good convertor. Pretty car, I like it. Good luck!
