Toilet tank (stupid) question? #3058773
07/13/22 06:54 AM
07/13/22 06:54 AM
Port Huron, Michigan
MI_Custumz Offline OP
Had to pull the tank to paint the walls behind the toilet. I put in new tank bolts and seal. I have water dripping from the bolts. Not a lot, but enough to annoy me. I don't want water damage if it gets worse. I installed the metal washer then the rubber washer onto the bolt so the rubber is against the tank, then same on the bowl part so the rubber is against the bowl. It has 3 bolts on it, basically a left, right, and rear. I do not want to over tighten the bolts and crack the tank or bowl. How tight should they be? I read hand tight plus 1/4 turn. Well, hand tight for some is not the same for others. I have the left and rear dripping slightly and the right seems fine. I have paper towels under it to monitor it. Is this one of those weird things where tightening the one bolt will make the others appear looser? I am using a socket and just my index finger to tighten it basically.
Re: Toilet tank (stupid) question? [Re: MI_Custumz] #3058777
07/13/22 07:13 AM
07/13/22 07:13 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
I would get new rubber washers and smear them with vaseline or plumber's grease before installing them.
I once hired a nephew to paint a house we had bought. He jammed his hand behind the tank to paint. The next day the basement was flooded.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Toilet tank (stupid) question? [Re: MI_Custumz] #3058779
07/13/22 07:23 AM
07/13/22 07:23 AM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
do not use metal washers in the tank, use only rubber washers, I retired from plumbing work & I guarantee that if you have a metal washer in the tank it will leak, best way to do this use a bolt & rubber washer inside the tank, use a metal washer & nut on the bottom of the tank well tightened, attaché tank to bowl with a metal washer & nut , tightened while applying pressure down on the tank, these do not need to be ungodly tight
Re: Toilet tank (stupid) question? [Re: Bob Stinson] #3058780
07/13/22 07:24 AM
07/13/22 07:24 AM
Andrewh Offline
Andrewh  Offline
so you have to tighten to crush the seal between the bowl and tank.
but not enough to crack the porceline.
if you press down on the tank, how much more give is there to the bowl is what I look for.
that gives you an idea of how much more you can tighten.
I mean don't lean 200 pounds on it, but push down and see how much give you get.
Re: Toilet tank (stupid) question? [Re: Andrewh] #3058790
07/13/22 08:18 AM
07/13/22 08:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
THIS !!!
The bolt heads are large enough to spread the load, no washer needed. The washer goes under the nut.
Re: Toilet tank (stupid) question? [Re: Stanton] #3058810
07/13/22 09:45 AM
07/13/22 09:45 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The old question of how tight is too tight bothered me for years. Finally a local handyman who has been doing this for years pretty much put my fears to bed. He said that virtually all toilets have some sort of ridges on the bowl that the tank sits on. Tighten the bolts until the tank contacts these ridges and give it about 1/4 turn more and you are set.
Re: Toilet tank (stupid) question? [Re: Stanton] #3058835
07/13/22 10:57 AM
07/13/22 10:57 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
Originally Posted by Stanton
Quote
THIS !!!
Also look at the bottom of the bolt head to be sure it does not need to be filed flat.
The tank seals are generally neoprene and seal easily to the porcelain. Any machine or mold marks on the bottom of the bolt head can be the source of leaks.
The latest one I used included 4 neoprene washers one pair inside of tank sealed by by the bolt head with use of a brass washer and nut tightened against the tank before setting tank on bowl. Once assembled like that the tank tank with "studs" then dropped onto the bowl and the second set of neoprene washers installed and held by another brass washer and wing nut. The instructions it said the middle washer and net were not required, thus I left them out and never had tank seal leak (3 toilets done this way
Make sure to clean porcelain and insure other fittings are sealed tight as well It may not be the bolts. I do not use any sealants or grease unless recommended by manufacturer.
Re: Toilet tank (stupid) question? [Re: srt] #3059057
07/13/22 10:55 PM
07/13/22 10:55 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Silicone is your friend.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Toilet tank (stupid) question? [Re: mopardad] #3059099
07/14/22 06:11 AM
07/14/22 06:11 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I install toilets all the time in my business. This is the way to do it. Listen to the retired plumber.
Re: Toilet tank (stupid) question? [Re: fastmark] #3059102
07/14/22 06:57 AM
07/14/22 06:57 AM
Thanks for all the replies. The bolt replacement kit didn't have instructions on it. The seal looked good, so I just got bolts. I decided to get the kit with the bowl/tank seal this time. Figured I didn't want to reuse the rubber washers from the incorrect install. I noticed the package had instructions on it and they matched what was said here. Funny, the bolt set up that came off was not the same as the instructions said. Tank is back on and no leaks. I know it may be a stupid question to some, but I really appreciate the knowledge on the board.
Re: Toilet tank (stupid) question? [Re: MI_Custumz] #3059201
07/14/22 02:04 PM
07/14/22 02:04 PM
moparx Offline
moparx  Offline
tighten the bolts until they strip or break, then back off 1/2 turn............ biggrin [sorry, i couldn't resist]
beer
Re: Toilet tank (stupid) question? [Re: moparx] #3059339
07/15/22 06:19 AM
07/15/22 06:19 AM
beer
It's a porcelain toilet, so I think it would be back off 1/4 turn after it cracks.
Re: Toilet tank (stupid) question? [Re: MI_Custumz] #3059401
07/15/22 01:21 PM
07/15/22 01:21 PM
moparx Offline
moparx  Offline
beer
up i forgot about the tank being made of porcelain. my mistake, you are correct sir ! laugh2
beer
