what temperature do the outlets show, using a probe type thermometer ?
in a typical FSM, there are charts showing outlet temperature to outside temperature, as well as high and low side pressures compared to outside temperatures.
one thing you don't want to do is over charge the system.
how is it cooling/engaging the compressor clutch using defrost when you don't have defrost ?
i'm missing something here.
one of the components to be used in AC systems are a binary or trinary switch. one of these [or maybe both] are used to turn on the compressor clutch when the control switch is set to defrost.
using the AC in this mode removes the moisture on the glass quicker, in other words, a safety feature.
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
