Oil sending unit #3058533
07/12/22 10:21 AM
07/12/22 10:21 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Can you tee off the oil sending unit to run an oil pressure gauge and keep the idiot light working? on a 440
Thanks Tom RR
Re: Oil sending unit [Re: TOMRR] #3058538
07/12/22 10:54 AM
07/12/22 10:54 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Yes.
Re: Oil sending unit [Re: Lee446] #3058545
07/12/22 11:27 AM
07/12/22 11:27 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yes. On BBs you can use the 2nd port for that galley that's always plugged. Look about 1.5" to the passenger side from the existing sender.
Re: Oil sending unit [Re: TOMRR] #3058610
07/12/22 03:17 PM
07/12/22 03:17 PM
Thanks Tom RR
I've had to do that more than once when using spray bar valve covers, works good wrench scope
Re: Oil sending unit [Re: Cab_Burge] #3058621
07/12/22 03:41 PM
07/12/22 03:41 PM
moparx Offline
moparx  Offline
i've done it on all engines except a second generation 426 hemi. [never had one of those to work on]
a T fitting works good. i prefer to use brass fittings instead of steel or iron plumbing stuff.
you can also use stainless as well if you prefer, and can source those.
as an aside, i use a good quality teflon paste sealer, such as Loctite brand 567.
beer
Re: Oil sending unit [Re: topside] #3058627
07/12/22 03:53 PM
07/12/22 03:53 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Yes you can use the second one that is always plugged, but I believe it is a larger thread size and will likely need a reducer.
I found it's easier jut to use a "T"
Either way will work.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
