Torqueflite strength?
#3058281
07/11/22 03:21 PM
07/11/22 03:21 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have been considering a move to a 580 cu in 572-13 motor with 15/1 compression on methanol. Expected power would be over 1050 hp at 7400 rpm. Torque will be 800 + somewhere. Can stock input and output shafts handle this kind of power? Launch will be about 4800 rpm or less, with a converter that will flash to 6300 behind this beast. Tires are 10.5 x 33 hoosiers so shock from launch shouldn't be too bad. Tell me your experiences of stock shaft failures so i can figure out whether i want to try this.
Re: Torqueflite strength?
[Re: 440Brian]
#3058334
07/11/22 05:41 PM
07/11/22 05:41 PM
Posts: 10,043 MN
JERICOGTX
MN
At that power, and your weight, I don’t know why you haven’t switched to a glide? Engler switched to a Glide in his 3400lb Coronet this year, and in 5 races he’s pocketed $11,000 this year. It made the car deadly consistent.
69 GTX
68 Road Runner
[Re: gregsdart]
#3058346
07/11/22 06:16 PM
07/11/22 06:16 PM
Posts: 2,933 A shed in England
Tig
A shed in England
We snapped an o/p shaft when a ring and pinion failed (Dana). We replaced both the i/p and o/p with H/D ones on the rebuild and it lived behind a 900+ft/lb 655 wedge with no apparent issues. Long term, we intend to switch to a TH400 derivative box and a 9" type rear.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: gregsdart]
#3058349
07/11/22 06:18 PM
07/11/22 06:18 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I'm thinking of calling Pro Trans, 661-940-7400, about buying and using one of their custom built Pro Flights for my new Top Sportsmans B1-MC headed car. I know one west coast 10.5 outlaw racer that used them with really good results making near 2000 HP
[Re: JERICOGTX]
#3058353
07/11/22 06:34 PM
07/11/22 06:34 PM
gregsdart
At that power, and your weight, I don’t know why you haven’t switched to a glide? Engler switched to a Glide in his 3400lb Coronet this year, and in 5 races he’s pocketed $11,000 this year. It made the car deadly consistent. Because its fun,, 😁people would come to the line and watch to see what would happen this time,😵💫😲
[Re: gregsdart]
#3058406
07/11/22 09:52 PM
07/11/22 09:52 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I was twisting input/ output shafts at around 800 hp. 3700 lb car, mid nines 1/4. Went to A&A input/output shafts and had zero problems after that. The car eventually was running high 8s @155 at 3700 lbs with a 3.50 rear gear. Engine was making some good power and had a lot of weight and gear ratio to fight. Trans was reliable and predictable.
[Re: TRENDZ]
#3058409
07/11/22 10:06 PM
07/11/22 10:06 PM
gregsdart
I was twisting input/ output shafts at around 800 hp. 3700 lb car, mid nines 1/4. Went to A&A input/output shafts and had zero problems after that. The car eventually was running high 8s @155 at 3700 lbs with a 3.50 rear gear. Engine was making some good power and had a lot of weight and gear ratio to fight. Trans was reliable and predictable. Where were the output shafts breaking? I plan on at least an upgrade to the input shaft and hub. I figure on leaving a bit soft since i have a lot of gear and only an 8.50 cert
[Re: gregsdart]
#3058432
07/11/22 10:56 PM
07/11/22 10:56 PM
Posts: 263 CA, USA
JcodeCharger
CA, USA
I run a Torqueflite from Protrans. Its a killer piece. Billet input and output shafts, no stock internal in it. It was 1/3 the price of a similar TH400. I have put over 50 passes on it. I leave at 12 psi of boost which is good for just over 1,000 hp and probably similar torque since I leave at 4800 rpm. Zero problems with it.So far my 3400# car has gone low 8's with this combo.
68 twin turbo Dart 8.19 so far 70 Swinger 360 69 Roadrunner 383 4 speed 69 Mod Top Satellite 383 auto 69.5 A12 Super Bee 4 speed 70 T/A Challenger 70 FC7 Duster 340 4 speed 70 FJ5 Superbird 68 Hemi 4 speed Roadrunner 71 Duster W2 340
[Re: gregsdart]
#3058433
07/11/22 11:01 PM
07/11/22 11:01 PM
TRENDZ
Milwaukee WI
never broke a shaft, always twisted them. the lube holes in the shafts would go from round to oval, and the slines would have an offset twist in them.
[Re: dart games]
#3058527
07/12/22 09:27 AM
07/12/22 09:27 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
put a powerglide in it and be done.or be like this that's what happens with a stock sprag and a stock front drum ...
[Re: JohnRR]
#3058532
07/12/22 10:08 AM
07/12/22 10:08 AM
Posts: 4,101 Yes
sixpakdodge
Yes
put a powerglide in it and be done.or be like this that's what happens with a stock sprag and a stock front drum ... Guy's like a broken record. Doesn't matter if you fried a clutch, or broke a hard part...he posts that same picture with the same stupid comment.
[Re: gregsdart]
#3058537
07/12/22 10:52 AM
07/12/22 10:52 AM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
I have been considering a move to a 580 cu in 572-13 motor with 15/1 compression on methanol. Expected power would be over 1050 hp at 7400 rpm. Torque will be 800 + somewhere. Can stock input and output shafts handle this kind of power? Launch will be about 4800 rpm or less, with a converter that will flash to 6300 behind this beast. Tires are 10.5 x 33 hoosiers so shock from launch shouldn't be too bad. Tell me your experiences of stock shaft failures so i can figure out whether i want to try this. I can say, I have never pushed one that hard....We have made 850hp and had no issues....We build them per what A&A recommends for parts for that level. At your level, a glide will probably be cheaper and hold up better. The only thing is with a glide, it tends to take a couple tries to get the convertor where you want it. Much fussier without that extra gear to get you moving. ... Now I have a friend pushing a 727 to 1200hp in a blown application, and it can be done, but he seems to find the limits of everything, and that is where he cracked a case....I don't think there was anything else that failed on him.
[Re: Dragula]
#3058742
07/12/22 11:58 PM
07/12/22 11:58 PM
gregsdart
I have determined that i need a better input shaft and hub, the rest, except for the output shaft, is good parts . To keep it alive with a 580 i figure a short part throttle launch will suffice. Once the car gets moving a foot or two stresses start to drop pretty fast. So maybe leave at 4000, .2 or . 3 at half throttle, it should live and maybe, just maybe i can stick the tires!
[Re: cudaman1969]
#3058872
07/13/22 12:52 PM
07/13/22 12:52 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
I have a Joels on Joy proflite behind my 64. Was 3600lbs with me in it and makes 4 digit power(8.80's 155)
