Dodge dealer tech questions
#3057977
07/10/22 01:26 PM
07/10/22 01:26 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I just finished rebuilding the 360 in a 1999 Dakota. We used a scan tool to sync the base timing and it fired right up first try. Runs great, no leaks. Took for a test spin seemed sluggish like taking off in high gear. Hooked scan tool back up and it does show trans is stuck in 3rd gear. Has all of these error codes. Tried to clear them but they come right back.
Odd thing is transmission was not touched. It was supported with trans jack during the rebuild of engine. Didn't touch anything on the trans other than bellhousing and torque converter bolts. None of these issues or codes were present before engine swap.
How would doing an engine swap cause all these transmission codes?
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Dodge dealer tech questions
[Re: 6PKRTSE]
#3058007
07/10/22 04:31 PM
07/10/22 04:31 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Check all your grounds and connectors. Disconnect the battery, press the brake and hold it and turn the key to On & then Start for 2 to 3 seconds while doing this, then restore and recheck.
There used to be a sharp Tech at Solo PCM's in Florida who may know what's going on if the above doesn't work. Best of luck.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: TJP]
#3058467
07/12/22 12:00 AM
07/12/22 12:00 AM
6PKRTSE
Motor City
It got dark on me on Saturday night. I will try to look at it again tomorrow after work. Thank you all for the suggestions.
