Timing Chain Tensioner Failure 5.7 #3057923
07/10/22 11:04 AM
07/10/22 11:04 AM
Seattle WA
RichV Offline OP
RichV  Offline OP
Seattle WA
How common are timing tensioner failures? Does the current 5.7 use the metal and plastic tensioners or do they use a all plastic version? I am aware that the 6.4 uses the metal and plastic version, but is this needed upgrade for a driver 5.7 or a nice to have upgrade?
Re: Timing Chain Tensioner Failure 5.7 [Re: RichV] #3058040
07/10/22 07:36 PM
07/10/22 07:36 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Facts are stubborn things.
Re: Timing Chain Tensioner Failure 5.7 [Re: RichV] #3058218
07/11/22 12:56 PM
07/11/22 12:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
50,000 cars out of millions built and it is covered under a recall? I wouldn't lose any sleep over it. If you buy a car covered by the recall find out if it was performed, if not get it done before it breaks. Out of the hundreds of these engines I have worked on I have never seen one with a broken or jumped timing chain, defiantly seen wear on the plaz tech but never a broken one.
