Re: 2014 Jeep Patriot: Source of an Underbody Banging?
[Re: Powerflow]
#3057536
07/08/22 10:16 PM
07/08/22 10:16 PM
Posts: 10,589 Freeport IL USA
poorboy
Freeport IL USA
Sounds like defective motor mounts. I suspect your friend did a visual inspection and probably concluded the mounts were OK. If the motor mounts are anything like the motor mounts on our 2.4 PT, a visual inspection lies to you. You have to pull the bolt, or pry on the mount housing to see if its actually good or not. Wouldn't take much movement to let something hit on the body structure or the floor pan.
I don't know how the rear suspension is set up on the Patriot, but the PT has a Watts Link on the rear axle, after several years of service, that Watts Link developed a bang under certain conditions. As time moved on, it became very easy to find. If the patriot is equipped with a Watts Link, with the suspension hanging, hutting one side of it with a rubber mallet will show you the source of the noise it that is it.
Re: UPDATE: 2014 Jeep Patriot: Source of an Underbody Banging?
[Re: Powerflow]
#3060065
07/18/22 12:41 AM
07/18/22 12:41 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
My wife's 2012 Patriot latitude had a very similar sound. It turned out to be the aluminum heat shield above the muffler. The mounting holes on the shield had corroded away and it was just flopping around in there. I pulled it out and it quit making the noise. It hasn't caught on fire yet either and it's been a couple of years.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: moparx]
#3060194
07/18/22 12:19 PM
07/18/22 12:19 PM
Posts: 9,853 MI, usa
dvw
MI, usa
Grab the roof above the door. Rock the car right to left. If it makes the noise, have someone rock while you grab various components. You will feel what ever is loose. I'd be thinking sway bar links first. Doug
[Re: Powerflow]
#3071246
08/25/22 12:01 AM
08/25/22 12:01 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Powerflow, does this happen at very low speeds while driving? I had a new 2007 Charger company car that started with a front-end rattling/clunking (loud) sound very intermittently while driving at any speed, but most noticeable at very low speeds - ANY little bump you'd hit like even a crack in the cement would cause this. This started at a little over 30k miles. Had the lower control strut arms replaced - that did not solve it. Then one day we had the car up in the air while changing the oil & the shop manager came out to take a look after I described to the guys what was going on. I had even been to a well-renouned front end shop in the area, & they couldn't find anything wrong. So Ken (shop mgr.) grabs the front sway bar & on both sides of the engine cradle mounts & reefs on it. He said the two bushings were shot. Now they were not cracked or squished-out, but they were hogged-out some & they turned out to not be tight to the sway bar anymore. Once they were removed, they were ovaled-out. When the wheels hit bumps, the sway bar was sending a pretty good shock to the bushings causing the noise. I ordered some Energy Suspension bushings & this TOTALLY solved the noise. I would have never guessed this even if I was focusing on them.
[Re: Sunroofcuda]
#3071292
08/25/22 08:44 AM
08/25/22 08:44 AM
Posts: 1,296 New Jersey
Powerflow
New Jersey
Powerflow, does this happen at very low speeds while driving? The noise happens when taking off from a stop while making a turn. It doesn't happen unless you give some gas while turning, and sometimes it makes noise but most times it doesn't. The rear differential shakes and sounds like it's slapping the floor pan from underneath. The slapping noise decreased considerably with the new CV axles. The tech who did the work says it's OK to take on a long trip (leaving tomorrow) and even wrote it down on his bill. I'm thinking it may be the rear differential mount but so far I haven't been able to find any info online (like Youtube) to show the rear diff and how to change the mount. The saga continues......
[Re: Powerflow]
#3081299
09/27/22 10:30 PM
09/27/22 10:30 PM
poorboy
Freeport IL USA
I'm still working through the noise in the Jeep. At this point, all 4 CV axles were replaced (and I got nicely ripped-off in the process...) and the noise is still there. The noise sounds like it's coming from a rotating component. There is now a banging noise when going from drive to reverse. I put the Patriot on ramps and found rotating play movement at the rear differential flange (where the rear U-joint bolts onto it) of about about 1/2"- 3/4" if I grab the driveshaft and twist it. I'm not too familiar with differentials and don't know if that's too much. Can the rear differential be the culprit? I would be concerned about a 1/2" to 3/4" of free play on the pinion shaft. There was a several year run where the pinion nut could loosen up and allow a lot of slop between the ring and pinion gears. When the nut loosened, the pinion would sink back into the axle assembly. When it gets loose enough, it will bind on the ring gear and start breaking off teeth, which turns into a real mess real fast. Pull the driveshaft off the the rear yoke, and see if the pinion can move side to side, up or down, or in and out. Might put a socket on the pinion nut to see if it turns easily without moving the yoke. If that is OK, I think I would pull the cover off the diff.
