727 Gains RPM Issue #3055723
07/04/22 09:00 AM
07/04/22 09:00 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Trying to help out a friend.
NSS/MW car,10.70s 4.10gear. 493in wedge
Last year it would occasionally gain RPM about the 1,000ft mark.
Jump from 6,200 to nearly 7,000...car would slow 5 to 8 hundredths.
Had trans gone thru by a GOOD trans guy and fellow MW racer.
Only thing he found was some slippage on 3rd clutch.
Refreshed and back in.
Got worse.
Ordered a new converter 9.5".
Car picked up 60ft....but now gains RPM even more frequently.
Pulled the trans again...teardown...no damage or evidence whatsoever.
Is totally unpredictable, but he says it seems more frequent as it gains temperature...so installed bigger cooler and a gauge.
Never gets past 170.
I thought it sounded like it is not keeping the converter full..IE. emptying the pan.
Been through all the usual things..fuel pressure/volume ..ignition...shifter.
Ideas???
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055728
07/04/22 09:21 AM
07/04/22 09:21 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
What transmission fluid is he using?
Joe
Without Data, you’re just another guy with an opinion.
Re: 727 Gains RPM Issue [Re: sr4440] #3055737
07/04/22 10:41 AM
07/04/22 10:41 AM
N.E. Ohio
N.E. Ohio
Not sure.
Probably Type F
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055742
07/04/22 10:58 AM
07/04/22 10:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Is this per data recording?
Re: 727 Gains RPM Issue [Re: J_BODY] #3055747
07/04/22 11:06 AM
07/04/22 11:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have had the trans looked at a couple of times with nothing wrong, start looking elsewhere
wave
Re: 727 Gains RPM Issue [Re: J_BODY] #3055748
07/04/22 11:13 AM
07/04/22 11:13 AM
N.E. Ohio
N.E. Ohio
No...tach goes up ...car noses over.
Re: 727 Gains RPM Issue [Re: sr4440] #3055749
07/04/22 11:14 AM
07/04/22 11:14 AM
N.E. Ohio
N.E. Ohio
Joe
Type F from NAPA
Re: 727 Gains RPM Issue [Re: MR_P_BODY] #3055750
07/04/22 11:17 AM
07/04/22 11:17 AM
N.E. Ohio
N.E. Ohio
wave
Agreed...but what else will gain RPM and lose acceleration together?
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055754
07/04/22 11:23 AM
07/04/22 11:23 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check your line pressure in high gear. Might be some pressure loss?
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055756
07/04/22 11:36 AM
07/04/22 11:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Does this car have RPM limiters of any nature.. if so try to borrow some others... or get new ones
(not sure if NSS cars use them)
wave
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055817
07/04/22 12:29 PM
07/04/22 12:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm thinking the transmission guy is missing something awry in one of the clutches or the pump. Deep pan or shallow?
If the VB allows a line pressure gauge tap, a gauge plumbed into the cockpit might show a pressure drop at top end. If the center tap on the case is blocked, a gauge at the front servo will work.
Re: 727 Gains RPM Issue [Re: MR_P_BODY] #3055825
07/04/22 12:43 PM
07/04/22 12:43 PM
N.E. Ohio
N.E. Ohio
wave
I'm sure it has a MSD chip for max RPM.
I will find out.
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055828
07/04/22 12:44 PM
07/04/22 12:44 PM
N.E. Ohio
N.E. Ohio
He is going to install another transmission and see what happens.
So we'll see what happens.
I'll update when he gets results
Thanks everyone....
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3055984
07/04/22 09:47 PM
07/04/22 09:47 PM
A727Tflite Online content
A727Tflite  Online Content
Got worse.
Ideas???
What do you mean he saw slippage on 3rd gear clutch?
What did he see exactly.
Any issues with change in the stall speed or 60’?
If you have a spare valve body I would try that first.
Re: 727 Gains RPM Issue [Re: A727Tflite] #3056091
07/05/22 09:36 AM
07/05/22 09:36 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
take a look at the lines to the trans cooler - are they a soft braided or a rubber line - you might be sucking one closed - also look at the cooler itself junk inside can act like a valve restricting flow
Also could be the valve body acting up - or the shifter is not aligned perfectly
Re: 727 Gains RPM Issue [Re: DoubleD] #3056107
07/05/22 09:46 AM
07/05/22 09:46 AM
Both cooler lines are under pressure at all times when not in park.
Re: 727 Gains RPM Issue [Re: A727Tflite] #3056125
07/05/22 09:54 AM
07/05/22 09:54 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I don't disagree - but pressure and flow are two different things in a hydraulic system
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3056138
07/05/22 10:07 AM
07/05/22 10:07 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Could be either clutch pack(s) or converter?
If the clutch pack is slipping, you should see the increased wear of the clutches and heat in the steels.
Some info in rear clutch pistons and bellview springs:
https://www.youtube.com/watch?v=V9Zl4gay5Jo&t=39s
Re: 727 Gains RPM Issue [Re: 6bblFLASH] #3056502
07/06/22 12:57 AM
07/06/22 12:57 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
wrong seals in clutch pack ?
Re: 727 Gains RPM Issue [Re: A727Tflite] #3056513
07/06/22 02:36 AM
07/06/22 02:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
[quote=DoubleD
isn't it around 30 lbs. or less pressure(maybe 15 to 20 Lbs. confused) to the tranny cooler
