Ladder bar set up help ( D150Truck)
#3055960
07/04/22 07:47 PM
07/04/22 07:47 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
Guys, I am wanting to double check the layout before I get too far along. I have the chassis at ride height, i have 3.5" of clearance from the axle to the framerail, the axle brackets are 90* To the ground , the Ladder bars are at 2.5* nose down , but the top of my front hangar bracket is 3/8" below the frame rail. Three questions,#1 is 3.5" enough clearance above the axle? ( single adj. CoilOvers) or do I need to c notch the framerail ? #2 the front hangar bracket and crossmember? What is my best option for tieing into the frame? Longer brackets? mounting the crossmember below the frame rail and gusset? Combo of both,? Options opinions please #3 this is completely wrong and I put it together upside down? Kidding.
Re: Ladder bar set up help ( D150Truck)
[Re: modelmakerinc]
#3056002
07/04/22 10:22 PM
07/04/22 10:22 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A rough guestimate of neutral line will be from the bottom center of the rear tire to the center of the camshaft at the front of the motor. It would be great to have at least one front adjustment hole below that line. I would start with a setting of one hole above the neutral line. Before final welding make sure you have enough adjustment to use all the holes. Box the housing brackets so they won't fold over (like mine did) if the vehicle gets out of shape. Invest in shocks consistant with the power you will have. I strongly advise going one step better than you think you will need. I am on my fourth upgrade in rear shocks . A bigblock and torqueflite make for a brutal starting line senario as power climbs.
[Re: modelmakerinc]
#3056302
07/05/22 02:14 PM
07/05/22 02:14 PM
Posts: 4,684 On the parachute mount
n20mstr
i would slip the box tube into the brackets, cut the bracket so the box tube is flush with it. weld all that to the bottom of the frame rail. put 1.25 tube gusset from the inside bracket to the box tube. plate the brackets on the front and put a 1.0 gusset from the plate to the bottom of the frame. Set the ride height with the bars level in the middle hole, this will give you adjustability up and down later on.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3056575
07/06/22 09:55 AM
07/06/22 09:55 AM
Posts: 1,840 NW Indiana
fbs63
NW Indiana
Set the ride height with the bars level in the middle hole, this will give you adjustability up and down later on. This is the most important. I would not have the bars pointing down as in your drawing unless you want a wheelstander.
[Re: fbs63]
#3056607
07/06/22 11:32 AM
07/06/22 11:32 AM
modelmakerinc
fbs63 This is the most important. I would not have the bars pointing down as in your drawing unless you want a wheelstander. lowering the front bars softens the hit on the tires, raising them adds BITE. And I am using the geometry spelled out in the manufacturers instructions FOR INITIAL set up. when the truck is finished the tuning will dictate where it goes
[Re: modelmakerinc]
#3056669
07/06/22 12:53 PM
07/06/22 12:53 PM
n20mstr
Raising the bar hits the tire harder, and increases chassis seperation, lowering the bar hits the tire softer and decreases the seperation. NO matter what , you are never getting rid of the seperation in a ladder bar suspension. THere will always be rise or seperation, thats why you need a GOOD shock with a ladder bar and a lot or decent power. For a daily driver or part time street strip car like this, i would put the bars level and adjust them at a test session depending on what the car does with the power it has.
[Re: n20mstr]
#3056694
07/06/22 01:34 PM
07/06/22 01:34 PM
modelmakerinc
N2Omstr 100% agreed thats what i said . albeit, differently this is my modified bracket, the notch on the bottom is for a kicker (brace) to the frame rail about 14" forward of the crossmember sorry for sideways pic
[Re: modelmakerinc]
#3056698
07/06/22 01:44 PM
07/06/22 01:44 PM
n20mstr
N2Omstr 100% agreed thats what i said . albeit, differently this is my modified bracket, the notch on the bottom is for a kicker (brace) to the frame rail about 14" forward of the crossmember sorry for sideways pic My idea of "street cars" with big block involves a boatload of nitrous and single digit time slips..... I also like low sitting cars trucks. That being said id trim the top of that bracket until the box tube was equal with the top (if that makes any sense) Also, pay attention to the ride height of the shock when setting this up. Make sure the brackets on the rear housing give you a lot of adjustment without lowering or raising the truck. Down the road if you get serious you will want a 15" ride height shock in there.... Sounds like a cool project
[Re: n20mstr]
#3056797
07/06/22 04:21 PM
07/06/22 04:21 PM
gregsdart
[quote=n20mstr]Raising the bar hits the tire harder, and increases chassis seperation, lowering the bar hits the tire softer and decreases the seperation. NO matter what , you are never getting rid of the seperation in a ladder bar suspension. THere will always be rise or seperation, thats why you need a GOOD shock with a ladder bar . [/quote I have a ladderbar, 30 inch, 106 wb, 3000 lb and in the bottom hole i am below the neutral line, and get no rise. The proof of this to me came when i had the front mount ON the neutral line. Due to torque roll the left ladderbar geometry went ABOVE the neutral line, and the right rear went BELOW it. All he!! Broke loose and the result was the car ripping the left rear off the track ( observed) when it ran out of shock extension and the car up on only the right rear for an instant. I run an anti roll unit now that is very beefy as i bent the first one on the first pass. I have posted the math on the forces at work on the hit. Over 20 times engine torque on the hit at the axles with a 2.45 low and 4.56 gear. For sure though, lots of shock control needed the instant those bars are above the line.
[Re: dvw]
#3057042
07/07/22 09:18 AM
07/07/22 09:18 AM
n20mstr
If the bar is level/down/up to the ground actually means squat. Where the front mount hole lays on the anti-squat line determines what the suspension will do. If it's above the anti-squat line it will separate. If it's below the anti-squat line it will squat. With most available rear ladder bar housing brackets this point usually ends up with the bar being level to the ground. That's why most people say level to the ground is a good staring point. but in fact it's a guess. Lengthen or shorten the bar? That point now needs to go down (shorter bar) or up (longer bar) to remain on the center of the Anti-squat line. Personally I'm not a fan of ladder bars on the street. A ladder bar set-up is a giant anti-roll bar. The housing can't roll rotate going around corners or up steep inclines while turning. This puts a lot of stress on joints, mounts, welds, and the bars themselves. It also induces over steer in hard cornering. Can it be done? Yes. But Caltracks or a 4 link is a better option for the street. Track only? They work great. As far as gusseting. I'd triangulate the front cross member at a 30-45 degree angle forward to the frame. Also nice to have the cage bars land on top of the ladder bar mount.
Doug Doug is correct on this, i just say level because thats how i measure my car. IT depends on the car because if it has a serious rake, then the ladder bars are really pointed up when you measure them as level. Doug is correct in that the ladder bars should be set in correlation to the anti squat line. It can get a little tricky. A digital angle finder really helps. Also helps to set it on your rocker panel for a reference to measure the cars rake , as well as the ladder bar angle. I hope i havent muddled this post up with this "technical" ladder bar info
[Re: n20mstr]
#3057589
07/09/22 05:07 AM
07/09/22 05:07 AM
gregsdart
To further muck up the waters, a little math on neutral lines. If your truck has a high center of gravity, or higher than the average door car, then the neutral line will be steeper. Taking camshaft height as a guestimate of c. g., Say 28 inch? If your wheel base is 120 inch, and ladderbars are 30 inch from axle center to front pivot, then the neutral line at the front ladderbar hole would be a percentage of the wheelbase . Ladderbar length (30 in) devided by wheelbase (120?) equals . 25 of the wheelbase times the actual c. g. Of 30 inch. So that would be . 25 x 28, or 7 inchs off the ground. If my calcs are close, then IMHO I would place the front ladderbar mount with the bottom hole at 6 inch off the ground or maybe 6.5. Since you will most likely be nose heavy, you will need to have rise. How much can only be determined by power, and the tires you run. Last thought, consider boxing part of the frame rails, from the ladderbar mount forward maybe a foot or so?
[Re: modelmakerinc]
#3057598
07/09/22 08:20 AM
07/09/22 08:20 AM
Posts: 879 Missouri
jwb123
Missouri
Get you a good 4-link/ ladder bar program and calculate all the geometry before you weld anything. I use performance trends. http://performancetrends.com/4link.htm Just from the photos it looks good. I know this program has saved me a lot of work over the years.
