Re: Timing light question
[Re: Ply36]
#3055927
07/04/22 05:39 PM
07/04/22 05:39 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
[Re: topside]
#3055955
07/04/22 07:25 PM
07/04/22 07:25 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
My older craftsman inductive with power from the car's battery worked very good when there was not an MSD involved, but did not work very good on MSD. It had a tendency to jump around a lot. So I bought the MSD self-powered. It works very well with the MSD, steady as a rock. And the self-powered feature is very handy so I don't have to hook it to power when the battery is not under the hood.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TJP]
#3056050
07/05/22 02:55 AM
07/05/22 02:55 AM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Most lights won't function correctly with a multi-spark ignition. The adjustable lights aren't accurate when trying to use to check total timing with the engine RPMs up.
Old non-adjustable Ferrets, old Sears/Craftsman/Penske inductive lights (2134, 2138), and any of those sold by MSD will. Adjustable lights should be avoided. Plenty of the old Sears lights on ebay, and occasionally, an older MSD chrome light or even a Ferret 81 show up. Or you can pop for a new MSD copy of the Ferret, MSD also does a battery powered unit. I think they are still made in the USA
