Re: Gas tank repair
[Re: BSharp]
#3055595
07/03/22 05:48 PM
07/03/22 05:48 PM
Posts: 1,841 South Bend
John Brown
South Bend
Might want to consider using a pop rivet. There are some that don't have an open center hole for liquid to leak out of. I used one years ago to seal a tiny pinhole in a station wagon tank I didn't want to remove. Used the pop rivet and covered it over with JB Weld. Was still holding several years later when I sold the car.
Re: Gas tank repair
[Re: BSharp]
#3055604
07/03/22 06:03 PM
07/03/22 06:03 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
weld--er-up...
to do it safely, fill the tank with water first to displace the fuel vapor
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
Re: Gas tank repair
[Re: GarageDodge]
#3055635
07/03/22 08:47 PM
07/03/22 08:47 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
My kid had his buicl stolen years ago They punched a hole in the tank to get gas/I used a screw after it was dry and clean.Then JB weld a piece of sheet metal and more JB.He drove it for 4 years sold it and it was here for like 3 or 4 more.Oh yeah my buddy welded tank just started his tow motor filled the with exhaust and welded away.Another firiend years ago tried to make sure no vapors were in the tank after water was in.Boom went probally 30 feet up.years later his arm still hurt from getting smacked with it
Chrysler Firepower
Re: Gas tank repair
[Re: GarageDodge]
#3055667
07/03/22 10:21 PM
07/03/22 10:21 PM
Posts: 1,757 Phila
PhillyRag
Phila
solder a piece of copper over the hole,has worked many times. Solder works great, but need to remove any galvanizing around hole first. Flux core solder if really clean, otherwise some acid core.
