Got my truck back!
#3055184
07/02/22 10:57 AM
07/02/22 10:57 AM
Posts: 43,579 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My fantastically bad luck may be changing the right way for a change (better knock on wood) LOL. The Columbia CDJR dealership in Tennessee where I dropped the truck off took a look at it and found a stuck exhaust valve and a bunch of metal shavings under the intake, so they ordered a new engine and said it would be ready on July 1st, but I held out little hope. I had to transport a 69 Dart GTS convertible to Hames Restoration in Mississippi so I headed down that way with my heavy duty open trailer. Just as I was dropping the car off I got the call, the truck was ready! So I headed over to Columbia, spent the night at a local motel (they really need more of them in that area) and got the truck in the morning. Took it for a short drive, everything seemed to be good, even the A/C was cold, so I loaded up and headed home and to my amazement the only traffic issue was just north of Nashville, no slowdown in Nashville for the first time ever! Did spend an hour and a half stopped dead on I-65 for an idiot who lost control of his open trailer and rolled the truck. Six ambulances and 10 cop cars later, they finally loaded everything up except the trailer which was still in a ball in the ditch on the side of the road. 340,000 miles on my chassis, 60K on the trans, and a brand new 5.7 hemi, thank you lifetime powertrain warranty, only $200 deductible for both!
JB Rhinehart, Realist
A-Body's RULE!
Re: Got my truck back!
[Re: Tom_440]
#3055307
07/02/22 05:44 PM
07/02/22 05:44 PM
Rhinodart
Rhinotruck
Rhinotruck
I'd say you got your money's worth out of that warranty. And you did this with no threats of bodily injury? Even a blind nut finds a squirrel occasionally...LOL..
A-Body's RULE!
[Re: Rhinodart]
#3055311
07/02/22 05:57 PM
07/02/22 05:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Just needed a cam and lifters and you got a new engine instead... AWESOME!
[Re: HotRodDave]
#3055331
07/02/22 07:39 PM
07/02/22 07:39 PM
Rhinodart
Rhinotruck
Rhinotruck
Just needed a cam and lifters and you got a new engine instead... AWESOME! They were concerned about the amount of metal shavings in the engine, and the fact I drove it about 400 miles before I brought it to their shop. Also, I don't know how bad the valve was stuck in the head, they probably decided that it would be cheaper to put in a new engine than to keep fixing it down the road, as I told them I plan on keeping it forever...
A-Body's RULE!
[Re: Rhinodart]
#3055339
07/02/22 08:37 PM
07/02/22 08:37 PM
Guitar Jones
R in a part number means reman. Nothing wrong with that though.
[Re: Rhinodart]
#3055364
07/02/22 09:41 PM
07/02/22 09:41 PM
HotRodDave
Kalispell Mt.
I bought one in tuscon with a completely flat lobe and drove it here (almost 2000 miles) and the bearings and such looked like new. I have torn apart a bunch with bad lobes (caused by bad lifter rollers) and never seen anything happen to the bearings even with 300,000 miles and a couple bad lobes. The guys at the local dealer always find "metal on the solenoid". They don't like putting cams in because an engine job is much better paying for the amount of work.
I seem to remember you bought this new and went with a 5.7 instead of 6.4 because no MDS correct? With that warranty if they are willing to throw in a whole motor then awesome.
[Re: HotRodDave]
#3055376
07/02/22 10:49 PM
07/02/22 10:49 PM
Rhinodart
Rhinotruck
Rhinotruck
I seem to remember you bought this new and went with a 5.7 instead of 6.4 because no MDS correct? With that warranty if they are willing to throw in a whole motor then awesome. Yes, bought it new and didn't want the MDS. Everyone who did hasn't driven theirs even half the mileage I had, so I don't know if that would have made a difference or not and I transport enclosed and open trailers constantly, so I am pretty happy with the miles I got. I wasn't pushing it hard when it went, but Alabama is never good to me and my trucks for some reason, so I have to quit going through that state...LOL..
A-Body's RULE!
[Re: 360view]
#3055452
07/03/22 10:48 AM
07/03/22 10:48 AM
Rhinodart
Rhinotruck
Rhinotruck
Good.
340,000 chassis miles
Engine and auto trans much younger.
what other truck components should be “renewed” to reduce on road break downs and headaches?
It is hard for me to imagine the driver’s seat cushions are protecting your spinal discs like one would hope for
are the body to chassis vibration isolators uncracked? I put one of those egg cushions on the seat 100,000 miles ago, and a vibrating backrest, I am old ya know?!? Don't even know what the "vibration isolators" are, rides like a buckboard from day one, so nothing I can feel has changed. Had front end components changed, all fluids changed recently, brakes are a year old, muffler has been rusted out for 3 years now, so maybe replace that soon. Tires are done, I have another set ready to put on. Who knows what will go next... My dealership recently got the exact same truck delivered, $51K and a 6.4 is all you can get now in a 2500, so no new one for me!
A-Body's RULE!
[Re: Rhinodart]
#3056701
07/06/22 01:48 PM
07/06/22 01:48 PM
Posts: 3,318 Great White North
Wheeler
Great White North
My fantastically bad luck may be changing the right way for a change (better knock on wood) LOL. The Columbia CDJR dealership in Tennessee where I dropped the truck off took a look at it and found a stuck exhaust valve and a bunch of metal shavings under the intake, so they ordered a new engine and said it would be ready on July 1st, but I held out little hope. I had to transport a 69 Dart GTS convertible to Hames Restoration in Mississippi so I headed down that way with my heavy duty open trailer. Just as I was dropping the car off I got the call, the truck was ready! So I headed over to Columbia, spent the night at a local motel (they really need more of them in that area) and got the truck in the morning. Took it for a short drive, everything seemed to be good, even the A/C was cold, so I loaded up and headed home and to my amazement the only traffic issue was just north of Nashville, no slowdown in Nashville for the first time ever! Did spend an hour and a half stopped dead on I-65 for an idiot who lost control of his open trailer and rolled the truck. Six ambulances and 10 cop cars later, they finally loaded everything up except the trailer which was still in a ball in the ditch on the side of the road. 340,000 miles on my chassis, 60K on the trans, and a brand new 5.7 hemi, thank you lifetime powertrain warranty, only $200 deductible for both! That's great news Rhinodart.
[Re: Rhinodart]
#3056778
07/06/22 03:38 PM
07/06/22 03:38 PM
HotRodDave
Kalispell Mt.
Good.
are the body to chassis vibration isolators uncracked? I put one of those egg cushions on the seat 100,000 miles ago, and a vibrating backrest, I am old ya know?!? Don't even know what the "vibration isolators" are, rides like a buckboard from day one, so nothing I can feel has changed. Had front end components changed, all fluids changed recently, brakes are a year old, muffler has been rusted out for 3 years now, so maybe replace that soon. Tires are done, I have another set ready to put on. Who knows what will go next... My dealership recently got the exact same truck delivered, $51K and a 6.4 is all you can get now in a 2500, so no new one for me! Nothing in the world wrong with a 6.4, I swapped one in my 2011 when the 5.7 blowed up and it is a beast and gets better MPG because it don't down shift anywhere near as much as the 5.7 did when towing witch is about the only time I drive it.
[Re: HotRodDave]
#3056972
07/07/22 01:40 AM
07/07/22 01:40 AM
Rhinodart
Rhinotruck
Rhinotruck
Good.
are the body to chassis vibration isolators uncracked? I put one of those egg cushions on the seat 100,000 miles ago, and a vibrating backrest, I am old ya know?!? Don't even know what the "vibration isolators" are, rides like a buckboard from day one, so nothing I can feel has changed. Had front end components changed, all fluids changed recently, brakes are a year old, muffler has been rusted out for 3 years now, so maybe replace that soon. Tires are done, I have another set ready to put on. Who knows what will go next... My dealership recently got the exact same truck delivered, $51K and a 6.4 is all you can get now in a 2500, so no new one for me! Nothing in the world wrong with a 6.4, I swapped one in my 2011 when the 5.7 blowed up and it is a beast and gets better MPG because it don't down shift anywhere near as much as the 5.7 did when towing witch is about the only time I drive it. Everything was the same in the swap even the computers? Chrysler recommends Premium fuel for the 6.4, is that what you use especially when towing? My buddy has a 2021 with a 6.4 and 8-speed and I get MUCH better fuel mileage with my 5.7 than he does. BTW, put 1,000 miles on it today towing, not issues and I figured I should break it in the same way I did when I first bought the truck...LOL
A-Body's RULE!
[Re: Rhinodart]
#3057023
07/07/22 08:14 AM
07/07/22 08:14 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Did Ram previously recommend premium with truck 6.4s? They don’t now. I just rechecked my manual and it says 87. Only the hipo 6.4 L in Challengers, Chargers, TRX and Grand Waggoner requires premium. I average around 16 and change. On highway trips I’ve been surprised to see the trip fuel economy readout reading 20-22 mpg. Doing the math in my head at the pump I think the readout might be a bit optimistic and the mpg is probably closer to 19 highway. With great difficulty me and a friend managed to free our late friend Don’s trailer out of his backyard last weekend, and then towed it 35 miles from the south burbs to the storage place. I didn’t reset the trip mpg feature so I can’t say what it will do towing, that is extent of my towing so far so can’t report on real world towing mpg. I’m guessing 9-10. I’ve seen guys on forums recommending using mid grade when towing, but given the fact 75% of what you read on forums is just guys stroking themselves, I don’t know if there is any merit to that recommendation or not.
[Re: Mastershake340]
#3057055
07/07/22 10:20 AM
07/07/22 10:20 AM
Rhinodart
Rhinotruck
Rhinotruck
I haven't kept up on the technology since 2015 when I bought mine but the short answer is yes, they did recommend premium for the 6.4 then, things may have changed and my buddy with the 2021 does run regular in his, but does not do much hauling. With the weight I tow all the time I wanted nothing to do with premium back then, and would really question myself now if I had to buy premium. Did you ever find out about the AAR?
A-Body's RULE!
