B-body 4 spd console attachment #3055119
07/02/22 06:02 AM
07/02/22 06:02 AM
BLACKHEMIRR Offline OP
Just wondering if anyone knows whether or not there was originally an attachment screw, down near the gas pedal, to hold the carpeted console side cover tight against the shifter hump? My console cover has one small original hole in it at the very bottom near the gas pedal, but I’m not sure if it was actually used. I’m working on a 70 Super Bee. If there was a screw there, was there a washer also? Thanks in advance for your help
Re: B-body 4 spd console attachment [Re: BLACKHEMIRR] #3056233
07/05/22 12:42 PM
07/05/22 12:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I can't remember there ever being a screw where you ask.
Re: B-body 4 spd console attachment [Re: JohnRR] #3056400
07/05/22 04:56 PM
07/05/22 04:56 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
My console never had a screw near the gas pedal.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: B-body 4 spd console attachment [Re: BLACKHEMIRR] #3056418
07/05/22 05:55 PM
07/05/22 05:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes there is. The front bracket has a hole on the side and the plastic console also has a slot on the side. As far as what screw is correct I am not sure. It pretty much is hid in the carpet overlay. I just found a suitable trim screw and painted it black.
