E-body gastank measurements?
#3054350
06/29/22 12:45 PM
06/29/22 12:45 PM
Posts: 2,578 sweden
1Fast340
sweden
Anyone have actual measurements of a E body gastank?
I know Lengt width and total depth are available online but im looking for how deep those tanks are front and back if that makes sense? Considering putting one of them under an abody that dont have the sparetirewell eating up space. but sure dont want a tank that hangs to low in the back therefore actualy measurements of how deep those tanks are would be nice before spending money.
And yes i know the inlet is on the wrong side,thats not a problem.
Re: E-body gastank measurements?
[Re: 1Fast340]
#3054566
06/30/22 02:05 AM
06/30/22 02:05 AM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
About 10 years ago, I wanted a larger capacity E-Body tank for my 1970 'Cuda. The stock tank has a pretty small capacity in relation to a big block Mopar's thirst. I worked with Hector at Rick's tanks and had him add extra width and a deeper stepped bottom to the stock dimensions. It bolts right into the stock location still, but holds more fuel. A few years back, I added a removable top plate and a couple Holley Hydramats with -10 pick-ups that feed an externally mounted, 2 speed Fuel Labs fuel pump.
I would never go back to a stock tank for many of the reasons you are attempting to resolve with your tank swap. Perhaps, you can give Hector at Rick's Tanks a call and see what might be the best path for you?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 1Fast340]
#3054776
06/30/22 08:58 PM
06/30/22 08:58 PM
jbc426
West Coast, USA
Ahhhh, I didn't notice you were from across the pond. I have some Mopar friends in Sweden and Auland Island that might be able to help you out with getting the measurements you need. PM me for their contact info.
[Re: 1Fast340]
#3055180
07/02/22 10:46 AM
07/02/22 10:46 AM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I'll try to remember to measure my old tank when I'm working on the car tomorrow...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3055637
07/03/22 08:51 PM
07/03/22 08:51 PM
Brad_Haak
Loudoun County, VA
Measured my '73 Challenger tank: - 26" long x 23" wide, including what I''ll call the flange that splits the top & bottom sections - forward end of tank is 11-1/2" tall - rear end of tank is 7-1/2" tall
