Carb to Scoop Clearance #3053632
06/26/22 08:33 PM
06/26/22 08:33 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
How tight are you guys running your carb to scoop clearance?
Right now I have about 6-3/4", which puts me about 3-1/4" below the hood plane.
I need to get a plenum spacer on this Indy Mod man intake, so I was thinking 2" would work.
With a 2" spacer I would be 4-3/4" from the scoop, and 1-1/4" below the hood plane still.
What have you guys ran that worked and didn't work?
Specifically this is a 62 max wedge scoop. My measurements are to the tall wide portions, not the shorter center rib.
Re: Carb to Scoop Clearance [Re: dizuster] #3053653
06/26/22 09:54 PM
06/26/22 09:54 PM
Locomotion Offline
Locomotion  Offline
I don't recall the measurements, but I'm at least sure the carb was below the hood surface. (360-4 Holley with 1"spacer.) I have a friend who had '65 Plymouth and corresponding scoop with the carb pan sealed to the hood. Car ran well but put up a random slower inconsistent ET with no pattern. When he cut holes/vents in the seal to the hood, the inconsistency went away. The only conclusion we could come up with was some type of turbulence within the sealed area of the carb inlet. Just another variable to consider when tuning
Either way, I believe 1" of clearance, no obstructions above the vent tops, should be enough. Same applies to an air cleaner top. I always likes the K&N Stub Stack to help smooth out flow when I was bracket racing. Carb needed 1 jet larger in my application when using one.
Re: Carb to Scoop Clearance [Re: dizuster] #3053748
06/27/22 09:43 AM
06/27/22 09:43 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
FWIW I was told by a reputable carb builder that 3/4" above the vent tubes is all that is required.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Carb to Scoop Clearance [Re: Plumb Wired] #3054432
06/29/22 03:57 PM
06/29/22 03:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have 2" from my carbs to my Super Shaker.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Carb to Scoop Clearance [Re: Plumb Wired] #3054716
06/30/22 03:46 PM
06/30/22 03:46 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I wonder if there's both a minimum clearance above the vent tubes and a minimum clearance above the venturis needed to ensure sufficient airflow... work
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Carb to Scoop Clearance [Re: dizuster] #3054843
07/01/22 07:23 AM
07/01/22 07:23 AM
Sterling Heights, MI
John_T_Brown Offline
1/2" above the vent tubes is all that is needed. I've been running the car that way for over 30 years!
If it ain't broke fix it anyway!
Re: Carb to Scoop Clearance [Re: Brad_Haak] #3054857
07/01/22 08:43 AM
07/01/22 08:43 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
FWIW, I asked this because the vent tube heights can vary significantly from one carb company / builder to another, so I figured there are likely two dimensions to take into account
Re: Carb to Scoop Clearance [Re: John_T_Brown] #3054861
07/01/22 08:47 AM
07/01/22 08:47 AM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
I have probably ran a little less than that even (use tubes on the vents to route to the valley). Car has always ran fine.
Thank you,
Casey FJ
