Diamond Sb mopar head flow #3054348
06/29/22 12:40 PM
06/29/22 12:40 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
I am picking up a set of diamonds heads with jesel rockers. Heads pressure test well @ 40 psi. Castings have never been welded. Has anybody flowed tested the large rectangle port aluminum Diamonds
Re: Diamond Sb mopar head flow [Re: 71Pan] #3054416
06/29/22 02:52 PM
06/29/22 02:52 PM
Never heard of them, do you have a link to them? help
Re: Diamond Sb mopar head flow [Re: Cab_Burge] #3054421
06/29/22 03:02 PM
06/29/22 03:02 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Pretty sure they are basically an aluminum W2? I cant remember if they came before or after the Batten head. Ryan J used to have some info them on his site. I seem to remember they were getting 320 or so out of them.
