Opinion #3054121
06/28/22 03:32 PM
06/28/22 03:32 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
Has anyone used a reground camshaft? Did it last as far as wear?
I have a couple of cams that the lifter failed on and they were hurt, one may be fixed with a regrind but the other has a chunk out of it and will need to be welded.
So what is the consensus?
These are billet roller cams.
Dave Covey
Re: Opinion [Re: Chief] #3054122
06/28/22 03:34 PM
06/28/22 03:34 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Wouldn't it be cheaper just to buy new?
Re: Opinion [Re: stumpy] #3054124
06/28/22 03:37 PM
06/28/22 03:37 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
I talked to Oregon Cams and they charge 199.00 These cams cost 600.00 new.
Not to mention if cores are available.
Dave Covey
Re: Opinion [Re: Chief] #3054127
06/28/22 03:40 PM
06/28/22 03:40 PM
an8sec70cuda Offline
I've used reground roller cams in GM LS engines and haven't had any issues. Haven't done one in several years, but there was a guy on ebay selling factory cams that were reground into a copy of the GM "hot cam" and some other grinds.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Opinion [Re: an8sec70cuda] #3054133
06/28/22 04:04 PM
06/28/22 04:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Back in the days of flatheads, that was common, but valve springs weren't all that stiff and there was more zinc & phosphorus in the oil.
I'd bet the specs were not as dead-on as we want now, though.
I would think a surface treatment on a re-grind would be really important, wouldn't it ?
Re: Opinion [Re: Chief] #3054139
06/28/22 04:22 PM
06/28/22 04:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I have run several that Comp Cams redid. No problems and you cant tell it from a new one.
Re: Opinion [Re: NITROUSN] #3054154
06/28/22 04:51 PM
06/28/22 04:51 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
It's going to have a smaller base circle which could be an issue if you already have a big cam with a small base circle.
I was told this by one of the major cam companies back in the mid 70's when I asked about regrinding a .770 lift Super Stock cam to a slightly different profile.
Re: Opinion [Re: Chief] #3054156
06/28/22 05:04 PM
06/28/22 05:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Delta Cams can weld them up, regrind them, heat treat them and so on. I suspect any good cam regrinder will do the same. Ask them for the answer.
https://deltacam.com/services/camshaft-grinding/
As for zinc in the oil, the flatheads don't really care, they have minimal valve spring pressures. A monster cam with battleship springs, yeah you're going to need zinc and such.
Re: Opinion [Re: Sniper] #3054164
06/28/22 05:41 PM
06/28/22 05:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ My point was that camshafts & lifters/followers back then had a much easier life.
Re: Opinion [Re: Chief] #3054171
06/28/22 05:52 PM
06/28/22 05:52 PM
I've had several solid roller steel core race cams reground and reused them, the key is the heat treating is still intact or reheat treat them twocents
Re: Opinion [Re: topside] #3054173
06/28/22 05:55 PM
06/28/22 05:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
With much crappier oil and filtration though. My feeling is that valve spring pressures are more important than it being a flat tappet setup.
Re: Opinion [Re: Sniper] #3054178
06/28/22 06:21 PM
06/28/22 06:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
In the 50s to 70s that’s about all you got
Re: Opinion [Re: cudaman1969] #3054179
06/28/22 06:42 PM
06/28/22 06:42 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I had Bullet regrind a solid roller can to to a different spec and it worked out fine.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Opinion [Re: Hemi_Joel] #3054287
06/29/22 08:52 AM
06/29/22 08:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We've used reground Mopar factory hydraulic rollers.
Doug
