Best boots for plugs wires with TF270 heads #3053693
06/27/22 12:27 AM
06/27/22 12:27 AM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
I have a set of TrickFlow 270 heads and will be using with TTI headers. Am thinking to go with Firecore wires. Should I use straight or 90 degree boots?
Re: Best boots for plugs wires with TF270 heads [Re: GTXMEX] #3053694
06/27/22 12:40 AM
06/27/22 12:40 AM
AndyF Offline
AndyF  Offline
You'll have to mock it up to see since it really depends on which header you are using. TTi makes a bunch of headers and the tubes are in different locations on them. I usually end up with a mix of different ends on the stuff I build.
Re: Best boots for plugs wires with TF270 heads [Re: AndyF] #3053699
06/27/22 01:12 AM
06/27/22 01:12 AM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Makes sense.
Re: Best boots for plugs wires with TF270 heads [Re: GTXMEX] #3053701
06/27/22 01:35 AM
06/27/22 01:35 AM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree With Trick Flow 240 heads and tti 1 7/8" headers on a RB, I ended up using 6 90 degree boots and two MSD "multiangle" boots at 135 degrees (45).
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Best boots for plugs wires with TF270 heads [Re: GTXMEX] #3053758
06/27/22 10:07 AM
06/27/22 10:07 AM
AndyF Offline
AndyF  Offline
Here is the engine from my Coronet. It has TF heads and the short try-y headers that TTi builds.
