Re: Brewer versus Passon Performance
[Re: GTXMEX]
#3053688
06/26/22 11:50 PM
06/26/22 11:50 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
What year and engine B body? 66-69 Hemi equipped 4 speed cars used a 172 tooth flywheel.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: GTXMEX]
#3053702
06/27/22 01:54 AM
06/27/22 01:54 AM
Posts: 43,274 Bend,OR USA
Cab_Burge
Look at the casting number on the lower right hand side of the back face of the bell housing facing the trans. and post it on here if you can't find that casting number application. I'm assuming it is a cast iron bellhousing and not an aluminum one, correct? The casting number will tell you the year and clutch and flywheel size that fit into it stock: scope:
[Re: GTXMEX]
#3053705
06/27/22 05:54 AM
06/27/22 05:54 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Need to purchase a new flywheel, and various back of engine and transmission related parts. Which is better to deal with? Brewer or Passon Performance?
And if I have a B body with a hemi 4-speed, it should be an 11", 143 tooth flywheel, right? Brewer's IMO I have dealt with both!
[Re: RATTRAP]
#3053781
06/27/22 11:57 AM
06/27/22 11:57 AM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
And if I have a B body with a hemi 4-speed, it should be an 11", 143 tooth flywheel, right? Brewer's IMO I have dealt with both! I’ve dealt with both. Brewer’s is my choice, bought a complete 727 to A-833 swap from them
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: GTXMEX]
#3053825
06/27/22 02:06 PM
06/27/22 02:06 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Both Brewers and Passon are experts for the Chrysler 4-speed hardware. But U need to check closely product availability, in today's market things can change very quickly. We have bought from both vendors, as they valuable supporters for our select Mopar cars. Just my $0.02...
