Re: Transmission fluid
[Re: Cab_Burge]
#3053324
06/25/22 05:38 PM
06/25/22 05:38 PM
Guitar Jones
ATF+4 is the best ATF you can buy. I won't use anything else.
[Re: glenngomango]
#3053430
06/26/22 08:58 AM
06/26/22 08:58 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Grab a NA Beer, go to that favorite chair, and read until your inner geek is mellow..... http://dastern.torque.net/techdocs/nonlamp/982674.pdfsample quote After evaluating the robustness of Chrysler’s current ATF, it became apparent that virtually every aspect of the fluid would require an upgrade to provide "fill-for-life" performance. Therefore, the goal of the project was to develop the new ATF with shift quality equivalent to that of the current fluid but with improved viscosity retention, thermal oxidation stability, low temperature viscosity properties friction and anti-shudder durability. ...snip... To further demonstrate the enhanced oxidation stability of the new Factory Fill Fluid, ATFs A, B and three other ATFs were evaluated in an extended test... ...snip... The results of this evaluation are shown in Figures 5 and 6. ATF C is the General Motors DEXRON-III Reference. ATF D is MERCON-V. ATF E is the Chrysler MOPAR ATF+ Type 7176 from 1993. end quote Figure 9 and Table 10 on friction values in Overdrive Clutch and Torque Converter performance deserves more than a quick look
[Re: Guitar Jones]
#3053538
06/26/22 03:19 PM
06/26/22 03:19 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
ATF+4 is the best ATF you can buy. Best at what? This fluid is designed to impart some slippage when components are applied. Great for lockup converters to prevent shutter and superior lubrication for OD's where the gears are constantly running but maybe not the best for non-lockup 3-speeds.
[Re: Sniper]
#3053570
06/26/22 05:02 PM
06/26/22 05:02 PM
John_Kunkel
Rio Linda, CA
You want an old, archaic formulation for your transmission fluid by all means use Type F.
Other than anecdotal claims there is no real benefit to it and lots of downside.
Elaborate. And no anecdotal claims.
[Re: 360view]
#3053627
06/26/22 07:53 PM
06/26/22 07:53 PM
Guitar Jones
When reading that 24 year old Lubrizol paper again, the words “fill for life” caught my eye.
Are there 1999+ Chrysler transmissions where factory ATF+4 is not recommended to be changed, ever?
My fuzzy memory is that a few of the Mercedes and/or Getrag auto trans were “fill for life.”
What company’s trans fluids were in those sealed units?
I would not think that in 24 years that there would not be ANY atf improvements..... Those fill for life claims are a little misleading. I believe it was stated for 100K miles under "normal" use. Nearly every single vehicle in use falls under the "severe" use catagory.
[Re: Guitar Jones]
#3053652
06/26/22 09:46 PM
06/26/22 09:46 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
Guaranteed for life, filled for life, and life time warrantees all mean about the same thing. When it breaks, its dead, and the Company's promises expired the day before. The fine print also tells you how they intend to get out of any liability, fortunately few read the fine print. It was guaranteed to meet the manufacturer's satisfaction, and they were happy with it as soon as you signed the paperwork. They are hoping it will last long enough for you to think you got good service out of it and will come running back to get the next one. Just add a company name to the guarantee.
[Re: John_Kunkel]
#3053722
06/27/22 07:57 AM
06/27/22 07:57 AM
Posts: 6,258 nowhere
Sniper
nowhere
Elaborate. And no anecdotal claims. You first
[Re: Sniper]
#3053804
06/27/22 01:05 PM
06/27/22 01:05 PM
John_Kunkel
Rio Linda, CA
In simple terms (for Sniper), ATF+4 costs considerably more than type F and this is significant when purchasing 10+ quarts for an initial fill up.
Some people seem to think that the latest version of everything is "the best", and maybe so in their opinion, but is it really needed? Newer fluids are formulated for OD and lockup...the OP's 727 has neither. Lockups need a friction coefficient that prevents converter clutch shudder and added lubrication properties for the OD gears that are in near-constant operation.
Putting +4 in a 727 is kinda like putting 93 octane gas in a /6 i.e. it'll work but is the added cost of benefit? As to the factory recommendation that +4 is "backward compatible" and therefore is the correct fluid for everything all the way back to the iron Powerflite...is that the best advice or is it just a way to alleviate the need for dealers to stock several different fluids in the service bay? Methinks it's the latter.
OK Sniper, your turn, tell us about the "downside".
[Re: JohnRR]
#3054315
06/29/22 10:25 AM
06/29/22 10:25 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anyone that uses the Mopar ATF+4 in their old style 727’s, 904’s, C6’s, turbo 350’s, and 400’s, and powerglides has to much money in their wallets and want to lighten it up some. Lol
