What choices have you used for an e-body aluminum radiator? #3053133
06/24/22 07:56 PM
06/24/22 07:56 PM
San Jose,CA
migsBIG Online happy OP
YouTube is my go-to news source
migsBIG  Online Happy OP
San Jose,CA
Getting ready for paint jail and decided while the car is away for the next few months, I need to order parts 1970 barracuda parts are hard enough right now, so finding a good quality radiator for an e-body with big block and and quality part in aluminum might be a challenge. I’m looking to paint it black and leave it in stock location. If the top tank looks stock, then that is just a bonus. What brand have you used in your car?
Re: What choices have you used for an e-body aluminum radiator? [Re: migsBIG] #3053137
06/24/22 08:11 PM
06/24/22 08:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just send the original to Glen Ray and have them up grade it. Stock looks better than a cheap looking non fitting aftermarket radiator any day. That is if you still have a factory rad.
Re: What choices have you used for an e-body aluminum radiator? [Re: migsBIG] #3053165
06/24/22 10:08 PM
06/24/22 10:08 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Just got a Griffin 26" aluminum rad last week for my 71 and also plan to paint it black. Top tank appears stock minus part numbers etc. American made and OE radiator shroud fits.
https://www.summitracing.com/parts/GRI-5-70058
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: What choices have you used for an e-body aluminum radiator? [Re: 71birdJ68] #3053166
06/24/22 10:08 PM
06/24/22 10:08 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
My opinion since I have just made a swap from big aftermarket aluminum to factory type stock,
I would just spend the money on a Glen ray replacement with the max cool option. Use the factory fan, shroud, and thermostatic clutch. Put a FlowKooler water pump and you won't be disappointed.
I had a fairly large aluminum radiator with a nice custom dual fan setup. It worked OK and never overheated but the fans draw way to much current and wreak havoc on the factory wiring and bulkhead connector.
My Challenger has a 572 Hemi with aluminum heads and 11:1 compression with a decent size solid roller cam and I swear the Glen ray radiator, stock fan & shroud, Hayden thermostatic clutch w/FlowKooler pump runs way cooler than the aluminum setup and electric fans.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: What choices have you used for an e-body aluminum radiator? [Re: migsBIG] #3053197
06/25/22 02:57 AM
06/25/22 02:57 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi look at rads on autocity 1958 e bay
got 2 1 for friend 440 and 1 for my hemi sat in traffic hot day never got above 195 verry pleased
top has ridges like original and inlet x outlet sizes correct no odd hoses
Re: What choices have you used for an e-body aluminum radiator? [Re: calrobb2000] #3053200
06/25/22 05:06 AM
06/25/22 05:06 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
I used a 26" small block aluminum radiator from us radiator, https://usradiator.com/ . It has stamped aluminum tanks so looks kinda stockish once painted black and the factory shroud bolted in place with no mods. It is a 2 row and keeps the 340 cool no problem in S Florida heat. It is the same one that OER sells.
Re: What choices have you used for an e-body aluminum radiator? [Re: turbobitt] #3053241
06/25/22 11:13 AM
06/25/22 11:13 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Allan G.
As you experienced running electric fans through the factory wiring is asking for problems. Got to run a relay hooked directly to the starter relay lug or battery. That and have an upgraded alternator of at least 100amp minimum.
Re: What choices have you used for an e-body aluminum radiator? [Re: migsBIG] #3053246
06/25/22 11:37 AM
06/25/22 11:37 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
If you want it stock looking and black, then earlier suggestion here may be the way to go.
I went to the oval track parts bin and installed a 3 pass aluminum unit utilizing GM style rubber mounts, using a stock shroud and fan. No way it looks OEM, but that was not my intent and it cools like a monster.
Re: What choices have you used for an e-body aluminum radiator? [Re: mgoblue9798] #3053260
06/25/22 12:06 PM
06/25/22 12:06 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Allan G.
All of what you mentioned was done but that's not going to fix the problem. No matter where the fans take the power from, the alternator still needs to make up the current draw and it all goes directly through the bulkhead and to the amp gage. A bigger alternator aggravates the problem by pumping more power through the bulkhead. The best way around it is to run a 8 gage or larger wire from the back of the alternator directly to the battery to bypass some of the charging current from the amp gage and bulkhead,
AG.
Re: What choices have you used for an e-body aluminum radiator? [Re: 71birdJ68] #3053272
06/25/22 01:15 PM
06/25/22 01:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree and if you don't have the stock unit he is repopping some and i believe he has a stash of used as well. He's not cheap, but QUALITY never is. I will also add he would've saved me about 18K or so on chasing a BB heating issue that magically vaporized with his core even though the radiator had a NEW core in it VERY LONG Story. twocents beer
Re: What choices have you used for an e-body aluminum radiator? [Re: TJP] #3053321
06/25/22 05:10 PM
06/25/22 05:10 PM
San Jose,CA
San Jose,CA
The original radiator in the car was from a 68' coronet and the car was a slant six. In other words, kind of a cobbled together cooling system. I'm having the radiator support increased to 26in from 22in and do not have a core I can or would use.
Thank you to everyone posting some radiator choices.
Re: What choices have you used for an e-body aluminum radiator? [Re: calrobb2000] #3053323
06/25/22 05:17 PM
06/25/22 05:17 PM
San Jose,CA
San Jose,CA
Tried looking them up, they do not appear on there any longer
Re: What choices have you used for an e-body aluminum radiator? [Re: migsBIG] #3053433
06/26/22 09:15 AM
06/26/22 09:15 AM
North Tonawanda
Checker Offline
Checker  Offline
North Tonawanda
I have always bought a Champion Rad for years. Best guarantee and price of any.
Re: What choices have you used for an e-body aluminum radiator? [Re: Checker] #3053441
06/26/22 10:16 AM
06/26/22 10:16 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
If you have the dimensions and what core row/style you are after have a look at the link. This is what is available under your vehicle but they make all kinds of radiators so you should be able to find what you are looking for.
https://www.northernradiator.com/AUTOMOTIVE_-_LIGHT_TRUCK/DODGE/CHALLENGER/1970
Re: What choices have you used for an e-body aluminum radiator? [Re: Moparite] #3053477
06/26/22 12:08 PM
06/26/22 12:08 PM
central il.
second 70 Offline
second 70  Offline
central il.
This 22" 3 core champion cools my 600HP Cuda easily. Instead of painting it I just polished it. Only had to redrill 1 lower hole. Other than that perfect fit.
Re: What choices have you used for an e-body aluminum radiator? [Re: A39Coronet] #3053729
06/27/22 08:18 AM
06/27/22 08:18 AM
an8sec70cuda Offline
iagree I have a big Griffin in my cuda and it's great. Looks stock when painted black also. Only downside is the cost.
The cheaper ones work good too, but don't have the stock look.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What choices have you used for an e-body aluminum radiator? [Re: migsBIG] #3053984
06/27/22 10:14 PM
06/27/22 10:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Be Cool 62087 if your willing to notch the folded over part of the frame a little to fit a 19x31 in there....Biggest rad able to fit in a B or E body
Re: What choices have you used for an e-body aluminum radiator? [Re: Dragula] #3054427
06/29/22 03:49 PM
06/29/22 03:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had a custom aluminum made for my Challenger street/strip car and painted it black for my stockish look. Sort of.... Came with Shroud and two Derale electric fans 2000 CFM each. One I turn on with overhead switch panel. The second fan kicks on from the Racepak above 180 degrees. And, I added -20 AN upper and lower weld bungs for my -20 hoses. It runs cooler than my more stock street cars on the street with over double the power.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What choices have you used for an e-body aluminum radiator? [Re: 6PKRTSE] #3054625
06/30/22 10:21 AM
06/30/22 10:21 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Got a cheap Champion off ebay about 5 years ago.My 65 built 440 runs super cool a day long.Only problem I had was adapter for lower hose to fit That was like 4 bucks No shroud amd still runs cool even when in the 80s 90s
Chrysler Firepower
Re: What choices have you used for an e-body aluminum radiator? [Re: 6PKRTSE] #3054629
06/30/22 10:29 AM
06/30/22 10:29 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yeah, 4000 cfm of air blowing thru any radiator would make it run "cooler than my more stock street cars on the street with over double the power."
