Mickey Thompson vs. Nitto street drag radials #3053083
06/24/22 05:50 PM
06/24/22 05:50 PM
Alliance, Ohio
V
Valiant_Showoff Offline OP
V
Alliance, Ohio
In the process of building a new ride and shopping for street/strip tires. I had Mickey Thompson E/T Street Radials on my '63 Valiant but have heard good things about the Nitto 555-R2 too. I was happy with the M/T's at the track, but they were dangerous on the street if you got caught in the rain. I have Nitto 555-G2's on my Scat Pack Challenger and they're very stable in the rain so I'm interested in trying the Nitto drag radial version of the 555's on my soon to be 360 powered '68 Cuda.
So the question is does anyone have experience in the difference at the track between M/T E/T Street Radials and Nitto 555-R2?
THANKS!
Re: Mickey Thompson vs. Nitto street drag radials [Re: Valiant_Showoff] #3053086
06/24/22 05:54 PM
06/24/22 05:54 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
nitto's did not hook at all on my Charger, they drove real nice, MT's or M&H hook great on my junker
Re: Mickey Thompson vs. Nitto street drag radials [Re: Valiant_Showoff] #3053124
06/24/22 07:45 PM
06/24/22 07:45 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I haven't been able to find NT555RII in the size I wanted to try out and bought M/T ET Street S/S instead.
From what I've read and heard talking to people who run the NT555RII at the track, the ET Street S/S works better. The Nitto drives better on the street and should last longer, but you're still talking a soft compound tire with a limited lifespan. A couple of people mentioned the NT555RII losing its grip after being heat-cycled from burnouts even though there is still a good amount of tread left.
Wish I had more firsthand knowledge, though.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Mickey Thompson vs. Nitto street drag radials [Re: Brad_Haak] #3053732
06/27/22 08:33 AM
06/27/22 08:33 AM
an8sec70cuda Offline
The Nittos are better on the street (more tread, harder compound), but that comes at the expense of dragstrip performance.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mickey Thompson vs. Nitto street drag radials [Re: an8sec70cuda] #3053744
06/27/22 09:26 AM
06/27/22 09:26 AM
WI
mopar873 Offline
mopar873  Offline
WI
^^This. The Nittos will last longer and be a touch better on damp roads, but honestly I would avoid any type of rain with the Nittos as well. I've had both on the same car the same track season, and the Mickey's had considerably more grip consistently. As mentioned above, the Nittos also do get erratic with a little too much burnout.
Re: Mickey Thompson vs. Nitto street drag radials [Re: an8sec70cuda] #3053752
06/27/22 09:56 AM
06/27/22 09:56 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Totally agree with this.
We have always used ET Street Pro's but a friend tried the Nitto's. On a low 11 second car he just could not make it hook consistently at the track. Switched to the Pro's and no issues.
'63 Dodge 330
11.19 @ 121 mph
Re: Mickey Thompson vs. Nitto street drag radials [Re: GY3] #3053868
06/27/22 04:18 PM
06/27/22 04:18 PM
Alliance, Ohio
V
V
Alliance, Ohio
Thanks for the feedback. Guess it will be a set of Mickey's.
