Broke a ball joint #3051842
06/19/22 10:14 PM
06/19/22 10:14 PM
Garry Owen Offline OP
Replaced the steering assembly years ago on my 06 2500 to the newer t style. This evening while hauling hay the passenger side ball joint let loose. It’s been so long since I did the work I can’t remember if the ball joints are replaceable or do I have to replace the whole tie rod?
Re: Broke a ball joint [Re: Garry Owen] #3051846
06/19/22 10:22 PM
06/19/22 10:22 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
Crazy where it broke, may have been a hairline crack from the factory. Hopefully you where not going fast when it snapped.
My Monster are real!
Living within your means makes life pretty easy.
Re: Broke a ball joint [Re: 67vertman] #3051938
06/20/22 10:50 AM
06/20/22 10:50 AM
moparx Offline
moparx  Offline
the whole tie rod is replaced as an assembly.
screw the old one off, counting the number of turns, screw the new one on the same number, and you will be good to go.
however, you should check the toe in to make sure it's in spec.
alignment shop, or there are several methods you can do at home. i'm sure the u-tube can show you how to do it.
beer
Re: Broke a ball joint [Re: moparx] #3052088
06/20/22 09:38 PM
06/20/22 09:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That one could be fun to get the broken stud out of! You have to remove the nut and push the stud out of the tapered hole from the threaded end.
Then as stated, you remove the tie rod end from the threaded sleeve, count the number of turns out, and thread the new one in the same number of turns, but don't forget to put the lock nut on first, if it fits on the tie rod end.
Re: Broke a ball joint [Re: poorboy] #3052178
06/21/22 01:12 PM
06/21/22 01:12 PM
moparx Offline
moparx  Offline
i would remove the broken stud by using a sturdy "pitman arm puller" type of tool.
provided it can be fitted, crank it up tight on the stud, apply some heat, then a sharp wack of a hammer.
repeat as necessary.
i have only had to do this a few times over the almost 60 years playing with our "toys".
a couple of these came loose surprisingly easy, while a few were real "fun".
the one thing you don't have to worry about is boogering up the threads. biggrin
OP, you can do this. it's really not as hard as it seems.
please let us know how you make out.
beer
Re: Broke a ball joint [Re: moparx] #3052906
06/24/22 10:21 AM
06/24/22 10:21 AM
Parts show up today. It’ll be this evening before I touch it.
Re: Broke a ball joint [Re: Garry Owen] #3053507
06/26/22 01:34 PM
06/26/22 01:34 PM
Just replaced the whole assembly. I measured center to enter on the ball joints for length, I’ll still have it aligned. For the broke stud I just loosened the nut and 3 lbs hammered it. I’ll post pics of the stud later as the metal at the shear looked odd to me.
Re: Broke a ball joint [Re: Garry Owen] #3053783
06/27/22 12:02 PM
06/27/22 12:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Your break looks like a twist type shear. I suspect the joint had seized into the ball socket. The strain of steering it was twisting it causing it to shear.
