Help identify BB adj. Rockers. Early 60s & back? #3051516
06/18/22 02:50 PM
06/18/22 02:50 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Pick these up along with a few sets of B & RB pushrods at a swap meet.
I thought they looked fairly OEM and not crane. Appear to be in good condition. Pushrods are definitely on the heavy duty 3/8 side.
Are these vintage/early aftermarket? Or are they OEM off like a 413 300 from the late 50s or so?
Chris
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: cdp] #3051524
06/18/22 03:15 PM
06/18/22 03:15 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
look like the same as Isky to me. I can't remember exactly what an OEM adjustable looks like but I don't think it is the same.
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: GomangoCuda] #3051526
06/18/22 03:17 PM
06/18/22 03:17 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Ok, thanks. I found some pics of Crane, and they are not them.
I thought maybe some other early RB's ~may~ have had adj. rockers other than MaxWedges, but have never actually seen any. And these don't have stands with them, like early heads had.
After doing a little research on the Isky, you were spot on.
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: cdp] #3051527
06/18/22 03:26 PM
06/18/22 03:26 PM
A727Tflite Offline
A727Tflite  Offline
Production arm should look much like the Isky but do not have the hardened inserts in them on the stem end.
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: A727Tflite] #3051558
06/18/22 06:34 PM
06/18/22 06:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
isky
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: cdp] #3051561
06/18/22 06:52 PM
06/18/22 06:52 PM
Cab_Burge Online work
Cab_Burge  Online Work
Those are the early Isky Ductile iron rockers for 1964 and later B and RB motors. Good stuff up
way better than the Cranes , Ersons and the other cheaper brands twocents
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: Cab_Burge] #3051618
06/18/22 10:29 PM
06/18/22 10:29 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Aren't Isky's marked? pic
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: GODSCOUNTRY340] #3051835
06/19/22 10:06 PM
06/19/22 10:06 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Yes, they turned out to be marked just like your picture.
It appears the shafts that these were bolted down to were over torqued, as they wouldn't come off over the thru holes. I had to gut the shafts in 2 to get the rockers off. No biggie, I have plenty of shaft sets laying around. Unfortunately, quite a bit of galling going on from what appears to be some low oil pressure. I little work needed.
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: cdp] #3051856
06/19/22 10:40 PM
06/19/22 10:40 PM
Stock BB hydraulic rocker arm shafts are NOT groove and drilled CORRECTLY for BB ductile iron adjustable rocker arms tsk scope
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: Cab_Burge] #3051998
06/20/22 01:55 PM
06/20/22 01:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Could be early Sig Ersons that had the adjusters changed. Mine I got in like 72 use the same type springs between them. Mine also have like thin rings for shafts also.I did change the adjusteres to MPs as the oes were an intererence fit and started working lose.
Chrysler Firepower
Re: Help identify BB adj. Rockers. Early 60s & back? [Re: therocks] #3052006
06/20/22 02:24 PM
06/20/22 02:24 PM
Erson and Crane ductile iron rocker arms never had the welded on harden wear pad like the Isky did tsk scope
All the Cranes and Ersons ductile iron Mopar BB rocker arms I've seen looked all together different, wimpeir, weaker than Iskys and stock Mopars do I've seen shruggy
