1966 Flexplate #3051480
06/18/22 11:52 AM
06/18/22 11:52 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Can a later Flexplate be used on 1966 273 engine or is the registry hole specific , have the correct converter but only the later Flexplate.
Re: 1966 Flexplate [Re: 426lloyd] #3051493
06/18/22 12:45 PM
06/18/22 12:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Depends on how LATE as in year ?
Re: 1966 Flexplate [Re: 426lloyd] #3051515
06/18/22 02:45 PM
06/18/22 02:45 PM
273 and some early LA318 motors had smaller crankshaft registers to center the flex plates and flywheels than the later one did, you need the correct flex plate or flywheel for YOUR motor scope
Re: 1966 Flexplate [Re: 426lloyd] #3051517
06/18/22 02:54 PM
06/18/22 02:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Difference in the crank flange register is the inside diameter, outside is the same I think. An early 904 converter hub is 1.550", later is 1.810" same as the 727.
Re: 1966 Flexplate [Re: John_Kunkel] #3051578
06/18/22 08:03 PM
06/18/22 08:03 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok I have the correct converter for the small 273 registry , so I guess I need a small registry flexplate also to fit the 273 crankshaft , correct , does anyone have the correct hole size for the flexplate .
Re: 1966 Flexplate [Re: 426lloyd] #3051586
06/18/22 08:30 PM
06/18/22 08:30 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What part of the outside register is the same and that the flexplate registers on that outside diameter do you not understand?
You can reuse your existing flexplate.
Re: 1966 Flexplate [Re: Sniper] #3051587
06/18/22 08:49 PM
06/18/22 08:49 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Let's try this , I have a1966 273 engine with a 904 transmission . The crankshaft has the small registry hole for the converter. I have the correct converter and need a flex plate . My question is will a 1968 and up flexplate work or is the the registry hole in the flexplate a different size for the 1966 .
Re: 1966 Flexplate [Re: 426lloyd] #3051593
06/18/22 09:20 PM
06/18/22 09:20 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
On the Slants the OD of the registers were different too. I always figured the small blocks were the same?
Re: 1966 Flexplate [Re: 426lloyd] #3051602
06/18/22 10:09 PM
06/18/22 10:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I believe what Sniper was trying to get across is the Flexplate "registers /centers) on the crankshaft "LIP" OD that raises anbe the flange and only needs to match the converter 4 hole pattern size wise.
And the converter Hub should match the crankshaft ID
Re: 1966 Flexplate [Re: 426lloyd] #3051747
06/19/22 03:11 PM
06/19/22 03:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
FWIW, the 273/904 flexplate part number for '66 is 2204403 (same for the /6), for '68-later it's 2400885.
Re: 1966 Flexplate [Re: John_Kunkel] #3051766
06/19/22 04:22 PM
06/19/22 04:22 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok so the raised lip on the crank might be smaller also for the flexplate
Re: 1966 Flexplate [Re: 426lloyd] #3051773
06/19/22 05:08 PM
06/19/22 05:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure the OD of the register.
Re: 1966 Flexplate [Re: John_Kunkel] #3051814
06/19/22 08:32 PM
06/19/22 08:32 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Crankshaft is in machine shop was trying to get the correct register size before it came back while I had the extra time , will have to wait for it to come back and try the 68 flexplate.
Re: 1966 Flexplate [Re: 426lloyd] #3051840
06/19/22 10:12 PM
06/19/22 10:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
just ask them to do a kwik measurement wink
Re: 1966 Flexplate [Re: TJP] #3052565
06/22/22 10:01 PM
06/22/22 10:01 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok , took the 1968 flex plate to machine shop and it fit the 1966 crankshaft perfectly , thanks
Re: 1966 Flexplate [Re: 426lloyd] #3052824
06/23/22 09:19 PM
06/23/22 09:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: 1966 Flexplate [Re: 426lloyd] #3052826
06/23/22 09:25 PM
06/23/22 09:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Sorry, late to the game.
I thought the change in the register diameter was done in 64/65. 66 should have been the later version.
For what its worth, as long as the flex plate fits over the crank flange, the larger diameter register flexplate still works on the small register flange. The 6 bolts will hold it fine. At least it did on the one I beat the crap out of for nearly 60,000 miles.
Re: 1966 Flexplate [Re: poorboy] #3052920
06/24/22 10:53 AM
06/24/22 10:53 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
ballsy IMO, LOL but hey it worked beer
Re: 1966 Flexplate [Re: poorboy] #3052958
06/24/22 12:16 PM
06/24/22 12:16 PM
A727Tflite Offline
A727Tflite  Offline
Geeez, I wonder why engineering spent all that time and money developing the fit and function of the flex plate pilot hole to crank flange radial and lateral runout spec.?
Re: 1966 Flexplate [Re: poorboy] #3052962
06/24/22 12:28 PM
06/24/22 12:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Better buy lottery tickets.
